deck lid body work???
87coupe
Taylors, SC
just wondering what's the best way to fill the holes in a deck lid like weld,bondo, what..... thanks in advance
87coupe
87coupe
Taylors, SC
ok thanks I didn't know cuz of how thin the metal was on the deck lid if welding was a little much
Slykin
Tyler, Texas
It may be a bit tricky, but i'm sure it can be done. It'll probably need some bondo/filler to smooth it out, but I can't see why it wouldn't work.
Musturd
Yea I welded mine closed and did my third brake light as well.
belber095
Ithaca, NY
seems like if you weld you'll have a lottttt of sanding to do. let us know how it turns out!
i've seen people just buy plugs for the holes and paint them to patch the car. that way they're not there, and you can still throw a spoiler on sometime if you want.
If its done right sanding should not be too bad with welding and as they said that would be the best way. Painted plugs are just ghetto fab if you can't do it right don't do it....
87coupe
87coupe
Taylors, SC
i agree about the plugs the asshat that had the car before me pop riveted 2 of the holes and left to exposed and open so i put 2 vinyl plugs in them to keep the rain out
I can understand people putting them in there to try out fer a day or two but after you decide you like it then get it filled/painted.
When you weld the wholes up make sure you use a series of tack welds and alternate between all the holes to prevent the panel from overheating and warping.
Tony
ohio
i'm going to be tackling this sometime here soon. what i plan to do is epoxy some small pieces of sheet metal on the inside where the holes are and just filling the holes with a good non shrinking filler. like seam sealr or something. i am super scared to try and tack or spot these tiny ass little holes, lol.
even thinking about going around the license plate box area and filling that seem. might do the 3rd brake as well! and the badge hole. completely shave the trunk lid, w/o any welding??? we'll see
you don't have to weld it if youu don't want too tony you could just put some mesh behind the hole to give the filler something to grap onto.
Tony
ohio
yea i dont think ya do either. a guy told me seam sealer doesnt shrink whatsoever and is sandable soooo, idk.
your local autoparts store probably sells a small body hole/patch kit that could fill the hole. Like I said above it comes with a metal mesh that you put in the hole and then put the filler into the mesh. If your worried about shrinkage just let it cure for a day or two before you start to sand it down.
ProKiller
PA
my guy welded the holes for the ford badge when i had the car repainted.
Musturd
Yea my trunk is smooth I've thought about doing the license plate seam but will see. If my body guy aka my dad is up for the task then will see how she goes.
2lowsn
That would be cool with the license plate seams filled. Is that box area metal? It feels like fiberglass or plastic lol.
Tony
ohio
you do yours first and if it turns out right i'll do mine...lol.
