Defiant's "Nightmare" Build Thread
Defiant
Defiant
CT
Got the rear left (#4) coil off and the plug was slightly loose too. So tightened it down and swapped coil packs around to confirm that it is indeed a dead coil and yep it is. Got a new motorcraft unit on the way.
Also a tip for others who have problems with getting the coil pack bolts off, use a 6 point wrench! I only had 12 point and ended up rounding a bolt off. I couldn't find any 6pt wrenches locally so I had to order a set of craftsmen wrenches.
The coils use a 7mm bolt, and the 6pt wrench got the rounded bolt off no problem! Not sure why these wrenches are so hard to find, thanks to craftsmen for saving my time. Definitely recommended for people with blower setups that limit the room for a socket to fit.
Defiant
Defiant
CT
Another acceleration run
[video=youtube_share;bbKU3dYo5ZM]https://youtu.be/bbKU3dYo5ZM[/video]
i really should do a run without the subwoofers
Defiant
Defiant
CT
Remember that melted looking fused wire by the MAF that I took a photo of?
i found a photo of another car with the same thing!
g36 monkey
Orlando, Fl
Car is really coming along!
For the rear end noise, as noted I would check into the bushings. The pinion snubber could also be worn out.
Defiant
Defiant
CT
Thanks dude
ok so I messaged that guy on the Saleen forum and he told me that fused wire is for the Saleen intercooler pump and fans. It's also not uncommon for the wiring to melt.
So I bought a new fuse holder and wired it in
the fans kick on so I assume everything's working as it should. Car runs the same (good).
Thomas_W
Capon Bridge, WV
If its common for that wire and fuse holder to melt, then its time to upgrade it.
Do they use a relay to kick the fans/pump on, or is it just direct driven through that wire/fuse?
Defiant
Defiant
CT
It goes to a controller in the fender well that runs off the factory ccrm.
Defiant
Defiant
CT
Yah we'll see. I put the new one in and it hasn't melted.
Btw I got tired of those chrome headlights so I bought some brand new OEM lights for it
Burninriverdiver
Glad to see you getting some bugs worked out. The chrome lights didn't look horrible but I think you made a good call on swapping back to the factory ones
Defiant
Defiant
CT
These were also a safety concern. Driving it tonight I noticed the light output is much greater than with the chrome headlights. I think that's because they were just halogen bulbs in a projector housing. These are nice and clear with new bulbs, I might get some PIAA LED bulbs in the future.
g36 monkey
Orlando, Fl
Make sure to seal those lights up around the seams. They have a tendency to get condensation if not OEM Ford.
Defiant
Defiant
CT
Just another photo from the front. No cool updates from me :p
ps: after rewiring the fuse holder for the fans and IC pump I noticed the temp gauge doesn't go to the right as far as it used to. Which was a complaint of mine, I think the blower is a lot cooler now, even in really hot temps it doesn't climb as high as it used to.
evilcw311
Most Evil Member!
Louisville, KY
Fan probably wasn't running since the old fuse holder was melted. Is it still making ticking noises or is it all gone now??
Defiant
Defiant
CT
I thought the ticking went away for a couple days but I do occasionally hear it for a second or two
btw I'm thinking of going wingless
Defiant
Defiant
CT
Like a cobra spoiler?
alright here's what I did. I pulled it off and began testing different nylon plug sizes.
cleaned off the left over gasket material with some rubbing compound. Some of it is permanently embedded into the clear coat which is unfortunate
I chose to use these "GM" plugs because they fit very snug and also match the paint
