DO I have to roll my rear fender lip to put on a 315/35-17??
SMOKEDURVTEK
pry a newb question you guys have all seen but i,m looking to buy some deep dish bullits that are 17x10.5 for the rear on some 315/35-17's? Do they pop right into place. Or does it take a bit work? Thanks in advance
SMOKEDURVTEK
My bad... Its a 95 Gt
scarface
Guest
you may have to, some do some dont. You will probably have to massage the inner fenderwell, and bend the ebrake cable.
scott5
myrtle beach, sc
i had to just bend the e-brake cable. It was not touching but it was too close for my likings. But other than that i am fine.. I also go eiback pro-kit springs on my car
spacemonkey
Mine fit with no problems other then the quad shocks.I fliped them and they were still rubbing the inside lip so I just ditched em.I have read since you can flip them and remove the dust covers if you still want to use them.
you MAY have to:
1.-Flip your quadshocks
2.-Roll your fenders depending on how low is your car
3.-Roll the inner fender
4.-bent your e brake cable
if your car is not lowered,i will just worry about the shocks and e-brake cable,good luck keep us update
SMOKEDURVTEK
slo94gt said:
you MAY have to:
Ok not too bad... My car is still factory height on 245's Looks like there is plenty of room. Maybe i'll give it a shot. I really want those rims ;D
i really wanted 335/30/18 out back but dont want to go thru the hassle of rolling my fenders is a PITA,take my quadshocks off,and bent my e-brake line,someone here has 335/30/18x10.5 on cobra rims,cant think of his name he has a green 97gt hmmm.ill get to you on that
gt96stang
i believe your talking about jonbeast...
But I had to ditch the quads and that was all for my 96..
yes jonbeast his car looks sick,who cares about the quadshocks just get some good adjustable arms and forget it
95Boss
The offset of the wheels will determine what problems you may encounter. I put 315's on my '95 and only had to ditch the quads (they still rubbed when flipped) and bent the e-brake brackets down. Fenders were fine. Some guys have had to move the exhaust tips over a bit. Whatever you have to do, it will be worth it.
SMOKEDURVTEK
So do you just ditch the quad shocks all together... or do you replace them? My car is sitting pretty high up So I'm sure the fender lips wont nee to be rolled up.
Trickflow.GT
what was the offset on your wheels?
redmustang95
i put some 315's on 17x10.5, i ditched the quad shocks without even checking to see if they fit with them on. i haven't had a problem.
[attachment deleted by admin]
Jerry santos
