I've got an update for you folk, 10 months later.
I'm working on an interior swap/fixing anything I came across. This is going to allow me access to all those never before seen wires. I paid for the interior of an entire car in full so I plan to grab the entire interior harness from the 02 I'm pulling things from. hopefully the locks are the same.
But anyways, today I was pulling off the driver side door panel when I noticed this little box and decided to open it up. To my surprise I see that had been water damage. I went down to the local junk yard and pulled a replacement from a 98 mustang. Changed it out. If anything this particular piece makes a clicking noise with the clicking of the windows. What does it do? I don't really know. relay maybe? Anyways, my locks no longer see to turn on the dash lights (seem, this isn't proven for sure yet). What has also developed is that my lock buttons don't seem to be doing anything now.
My left window still works in conjuction with either window button, however my driver side window does not, so I plan to pull the motor and open it up.
Ideas on fixing the locks or where to look next, though?
Also. Check out this sweet mustang. I wanted to post it somewhere.
http://9gag.com/gag/aWZ9oPn
Finally, I mentioned how my gauges were reading inaccurately (big surprise with this stock POS) but it was because the shop that did some work for me had possibly forgotten to bolt down the ground for it. Fortunately I found it and bolted it back down, but they're still pretty inaccurate so next I'm probably going to shorten the ground to see if that helps at all.
The high beam light was staying on because when I pulled the gauge cluster and put in back in the copper backings were starting to fray and cross eachothers paths, one next to it having power, turning the light on. lol.
