IRS is in, just waiting on a couple things to show up before I can button everything up and take it to be aligned. The shocks will be here tomorrow and a brake line adapter will be here sometime between Thursday and Tuesday... Fun notes about the swap that I've learned that nobody tells you:
Turns out that the '94-'95s are still using SAE brake lines and the connection where the rear axle connects is using 3/8-24 instead of M10x1.0 like the '96+ cars do and the IRS does. Also turns out, that when you're not an idiot and put the rear brackets on the right side, that one of the fuel line hold downs are right in the way of the bracket and you have to knock the rivet off and do a little re-routing. When we laid everything out in the floor as it came off the car, we didn't look to see if the brackets were on the wrong side when we got it and since the side holes lined up I didn't think to check until I'd already drilled the holes and welded the plates in and then went to mock up the cradle lol... Wound up having to cut the welds on the plates and notch them to fit in the new locations after drilling the new holes.
Also learned that the MM end link kit only comes with the outer tapered studs and not a new inner bolt which went with the other end links that I sold to lwarior along with an OEM spacer the '03-'04s had lol... Bought a replacement bolt and will just run an extra MM spacer like the '99 and '01s do and that'll be fine. And one more note, the subframe assembly is designed to go in front straight below and when you have stuff in the way to stop that, like say subframe connecters or bent sheet metal from where someone tried to jack up the car in the wrong spot at some point, installing the subframe from the back and sliding it forward is a major pain in the posterior as the frame rail flares out a bit and the cradle is too narrow to come forward into the LCA opening. Speaking of the LCA opening, you'll need to drill that out with a 9/16" bit to get the 14mm front subframe bolts to fit that come with the MM kit.
