Easy way to adjust headlights?????
JerZeyStangz
Northern NJ
Pull the corner markers off, and there is screw in the headlight tab. Screw in down, screw out up. Make sure the top tab, and outer tab on the headlight are justed flush with the bumper.
Justang
You don't even need to take the corners off really, just loosen the nut that holds them in until you can get a phillips screwdriver between the corner housing and the headlight housing. There are adjustment screws between there for vertical and horizontal alignment. A little twist does a lot more than you probably think, but all in all it's very simple to do.
