Eaton Swap links and writeups
Cobracarlo
Im looking for any eaton swap writeup links. There were a few I had saved on my old computer and cant find them now so if you have em post em.....If there is enough maybe we can even make it a sticky.
uncltrvlnmatt
Pa.
If you are useing your 98 engine you will need to buy a set of "C" heads. Your car has "B" heads.
C
Cobracarlo
yes i know what all imgoing to need. I have all the plans laid out. I was just looking for the links and ill have to save up and get the parts.
i have an assortment of parts as well (in case matt doesnt have what you need anymore.)
i also have a ballar teskid aluminum block you could use for your build....rated for 1,000,000,000 hp (or some jibberish like that)
C
Cobracarlo
thanks guys I appreciate it. As it stands right now I have a bare teksid block, a bare breand new 04 cobra block. An extra cobra crank. I will deff keep you guys updated on the build. I plan on using the 98 harness and computer. I know the 03 samples faster but it can be done with a 98. Im also planning on running an aviator pump with an inline pump like a t-rex. At least to start off with.
330CubeGt
GOOGLE yeilds some results, i just looked and there is quite a bit of info out there...
