Elrod's 5.0 Revival
ElrodKTPQ_89
ElrodKTPQ_89
Crossett, AR
Good to see ya moving forward. I'm confused when you mention tuning while I see the termiX screen sitting there. Is that just for monitoring things and not part of their tuning package?
Yea I got it separately just for monitoring. As for the tuning I know just enough about it to get myself in trouble lol. Danny Kimbler did the base tune for me and it hasn't been changed since that. I'm undecided on either taking it to a local guy with a dyno or getting with one of the guys that's been recommended to me from the holley/ford FB page.
ElrodKTPQ_89
ElrodKTPQ_89
Crossett, AR
Picking up from where I left off. Back in May I made a simple little bracket to mount the limit switch that will operate my 2-step. The arm of the switch rides on the clutch fork, and when the clutch is pressed in it completes the ground circuit for the relay. I’m gonna throw in a diagram that I based my setup off. It took me a while to get everything working how I wanted it but it works great.
I wanted to keep all of the wiring as clean and simple as I could, without having to run a bunch of wires in and out of the car. I grabbed a spare center console wiring harness from the wrecking yard and removed all of the wires that I would not be using. I used the 12v+ for the cig lighter circuit as power for the relay, ran thru a toggle switch that I mounted in a UPR switch panel.
I removed the ashtray and cig lighter from under the flip door in the console and mounted my momentary switch/button in the hole towards the front. (Will grab a pic of this and add later) I used one of the purple wires that goes to the convertible top switch for power to the momentary switch, and as stated the ground goes through the clutch switch. So when power is on to the relay, with the clutch down and one push of the button, the 2-step is activated and stays on until you let off the clutch, breaking the ground. I tested it out this weekend and it works really good. I’ll have to take some more pictures but it was a clean install being able to use factory wiring and keep everything hidden inside the console. The console and wiring can even be removed in one piece by removing the ground pin from the relay and disconnecting the harness connector.
Here’s a video that I got all my info from for anyone interested in this.
So I drove the car fairly often up until 4th of July weekend when I realized I had an exhaust gasket going bad. Since it was pretty much the hottest part of the year at that point I parked the car I. The shop and didn’t fix it until September. Grabbed a new set of gaskets but only changed the one on the passenger side for now. It was cooked well done.
While trying to get the headers back on, I dropped a bolt and it slid perfectly down one of the primaries into the void where they all merge into the collector.
Couldn’t get anything down in there to get a hold of it or anything. I refused to have a header bolt rattling around in there forever so I finally got it to move by wrapping a towel around the collector and blowing compressed air behind it until the pressure made it start traveling back the way it went in, and it actually stuck to a magnet just enough that I was able to direct it out to a point where I could grab it.
THEN I DROPPED IT AGAIN AND HAD TO DO THE SAME THING A SECOND TIME.
I even told myself I should probably put something there to block that off in case I dropped it again, but didn’t.
IDIOT. IDIOT.
Lolol. Moving on.
A couple months back I won a $100 gift card to Hanlon Motorsports and used that to get a driveshaft safety loop since I already had a Stiffler’s crossmember.
I’ve also picked up an Aeromotive 340 pump and hanger assembly, torque box reinforcements, new set of headlights and did some swapping and ended back up with the UPR rear suspension kit I got rid of a couple years ago - adjustable uppers and lowers with anti-roll bar and axle braces.
I’ve been planning some pretty major upgrades this winter if I go through with it all at the same time. Plan is to snatch the tank axle and rear suspension out and tackle all of it while everything is out. All of the rear suspension install plus the torque boxes, go through the axle while it’s out and probably invest in C clip eliminators and have the tubes welded plus a new cover, and do the pump upgrade along with new feed and return lines to get rid of all the stock lines. I also talked to Hanlon about getting a TKX so we’ll see what happens.
Next post I’m gonna dump some random pics of the car throughout the year.
ElrodKTPQ_89
ElrodKTPQ_89
Crossett, AR
Revisited one of my favorite spots
Trying out these new headlights. I hate the way the front of the car looks and had to do something to change it up a bit. Hoping to get some paint work done to the front if I wind up swapping to that cobra bumper. The smoked headlights also sucked for night driving, haven’t been out at night yet with these but assuming they’ve gotta be better. It’s almost bittersweet, headlights were the first visual mod I ever made to the car.
And an edited version. I think I need a new sig made with this pic.
Snorky
Nothing like a fresh, crisp set of head lights. I want to make oem colored retrofits so badly. That limit switch off if the clutch is a slick idea!
Daryl
Somis, CA
Been a minute since I’ve seen a post from you so welcome back into the fray! Car’s looking good and that’s some nice engineering you did with the 2-step. I’ve never seen or heard of that being the amateur level enthusiast that I am, but I can recognize great work when I see it. Congrats on a successful completion of that project. Cheers!
ElrodKTPQ_89
ElrodKTPQ_89
Crossett, AR
Thank yall. Last year when I was installing the MSD box I found a couple videos on youtube showing the clutch switch setup and decided I wanted to do it on mine. I may do a writeup/how-to on it at some point since I haven't seen too many threads or videos of installing the 6AL-2 in a 94-95 car specifically.
Daryl
Somis, CA
Check out TTSaleen on YouTube. He does tons of various videos that might be of interest to you.
95opal
Oh yea I've been sub'd to his channel for years. His last video has me wanting to add some nitrous to this car now lol
I wouldnt think twice about N2O youll love it.
My old HCI combo put down 425 on a wet kit.
Staff online
