Mod List PERFORMANCE- JLT Ram Air Intake Diablosport Predator Tune Professional Products Intake Plenum & 70mm Throttle Body ZEX Power Tune spark plugs MSD 2 Step Rev Limiter BBK Underdrive Pulleys Flowtech Long Tubes Flowtech Terminator X-pipe Bassani Cat-back dumped before axles Solid Motor Mounts TRANS- One of a kind custom faceplated TR3650 Steeda Tri-ax Shifter Steeda Quick relase Clutch quadrant w/ adj cable Stack Racing Firewall Adjuster Fidanza aluminum flywheel Centerforce Dual Friction clutch SUSPENSION- CHE lower control arms Baseline Relocated Upper Control arms Strange 10 way adjustable rear shocks Strange 10 way adjustable struts Stock rear springs Stock front springs -No front or rear sway bar CHASSIS- Jegster driveshaft loop Sub frame connectors SMR Torque box reinforcements Major Weight Reduction REAR- Moser 31 Spline Axles FRPP 31 Spline T-lok FRPP 4.10's Welded axle tubes Proform Perfect Launch Girdle DRAG- Jegs Sport Star wheels (15x10) 28x13.5x15 Hoosier QTP's Jegs Sport Star wheels (15x4) 165/80R15 Nankang CX-668 MISC- Autogauge 5" monster tach w/ shift light Rear seat delete Mach 1 Grille delete and chin spoiler Battery Relocation Line Lock Jegs pistol grip shift handle UPR pedal covers 261HP/299TQ
Currently in the works is a Teksid short block, ported and polished pi heads, long duration cams, eddy intake, e85, 4.56 gears, Team Z anti roll bar and ditched the 28x13.5 QTP's for 26x10 ET Drags
Heres a couple videos of the car https://www.youtube.com/watch?v=NyBRdkOBHNY&feature=youtube_gdata_player https://www.youtube.com/watch?v=inuEomRFyTs&feature=youtube_gdata_player
Slight change of plans. Not going to be using ported heads. Deal feel thru so I'll be using the Windsor heads I currently have. Got the block all set for the heads. Cams are on order and also on the way are a set of Brian Tooley Racing .550 valve springs with chromoly retainers. Once they get here I can assemble the heads and put them on
Man, that's a tough looking car! Love the white-letter Hoosier's on the back & the wiper cowl-mounted gauge. Just screams muscle to me.
