F8LGT's 2002 GT
f8l gt
Mod List
PERFORMANCE-
JLT Ram Air Intake
Diablosport Predator Tune
Professional Products Intake Plenum & 70mm Throttle Body
ZEX Power Tune spark plugs
MSD 2 Step Rev Limiter
BBK Underdrive Pulleys
Flowtech Long Tubes
Flowtech Terminator X-pipe
Bassani Cat-back dumped before axles
Solid Motor Mounts
TRANS-
One of a kind custom faceplated TR3650
Steeda Tri-ax Shifter
Steeda Quick relase Clutch quadrant w/ adj cable
Stack Racing Firewall Adjuster
Fidanza aluminum flywheel
Centerforce Dual Friction clutch
SUSPENSION-
CHE lower control arms
Baseline Relocated Upper Control arms
Strange 10 way adjustable rear shocks
Strange 10 way adjustable struts
Stock rear springs
Stock front springs
-No front or rear sway bar
CHASSIS-
Jegster driveshaft loop
Sub frame connectors
SMR Torque box reinforcements
Major Weight Reduction
REAR-
Moser 31 Spline Axles
FRPP 31 Spline T-lok
FRPP 4.10's
Welded axle tubes
Proform Perfect Launch Girdle
DRAG-
Jegs Sport Star wheels (15x10)
28x13.5x15 Hoosier QTP's
Jegs Sport Star wheels (15x4)
165/80R15 Nankang CX-668
MISC-
Autogauge 5" monster tach w/ shift light
Rear seat delete
Mach 1 Grille delete and chin spoiler
Battery Relocation
Line Lock
Jegs pistol grip shift handle
UPR pedal covers
261HP/299TQ
f8l gt
f8l gt
Currently in the works is a Teksid short block, ported and polished pi heads, long duration cams, eddy intake, e85, 4.56 gears, Team Z anti roll bar and ditched the 28x13.5 QTP's for 26x10 ET Drags
f8l gt
f8l gt
Got a team z anti roll bar. Now time to get rid of the air bag
f8l gt
f8l gt
Slight change of plans. Not going to be using ported heads. Deal feel thru so I'll be using the Windsor heads I currently have. Got the block all set for the heads.
Cams are on order and also on the way are a set of Brian Tooley Racing .550 valve springs with chromoly retainers. Once they get here I can assemble the heads and put them on
03DSGGT
SN95 Supporting Member
Akron, Ohio
Good looking build. Makes me anxious to get back to putting my Teksid together...
f8l gt
f8l gt
Thanks. It should've been done already but had issues with a set of heads
Barner1
Tennessee
Man, that's a tough looking car! Love the white-letter Hoosier's on the back & the wiper cowl-mounted gauge. Just screams muscle to me.
f8l gt
f8l gt
Thanks. It didn't quite look like that any more. Going thru a few changes
f8l gt
f8l gt
Got the valve springs, decided to get new valves so now I'm waiting on those
f8l gt
f8l gt
Lapping the new valves before install. Now to clean the heads and finally assemble them
Isaac cerr
