Edit: Saw I was missing a bolt on the tfi module because it broke in the hole. Well after buying a new coil...and tfi....I decided I'd check all connections before I moved onto the stator or dizzy. Took out the tfi and heat sink, drilled out the stuck bolt, retapped it then went and got a new screw from the home depoh. Put it all back in, and it fired up perfectly! Who woulda thought my only problem would be the ground? Well I let it warm up, filled it up with coolant, temp is now staying right at the N in normal. Here's some videos if it idling =]
http://www.youtube.com/watch?v=3zn_iSFAxfg
http://www.youtube.com/watch?v=uaFkAVuag9A
