fuel issues on my stock 95 gt
black 95 gt
this is my first 95 mustang gt all other cars were 87-93 fox bodies and im stumped my car has a mis to it i have changed head gaskets, cam (msd), ignition control module ,mass air,harmonic balancer,fuel pump,fuel filter, and regulater and the mis is still there also temp goes to 230-250 changed sensor and put auto meter temp gauge i have not changed injectors yet every once in a while the voltage gauge drops from above half to just under half also please help its driving me crazy
Mrstangerbanger
CHICO , California, United States
Sounds like you have more then one problem .. I would see if someone can hook up a diagnostic machine to the car like a snap on solus pro or something like that.. could be the CCRM having problems but could also be hundred more things the best thing to do is hook up a diagnostic machine to see what the computer is saying with KOEO ..
B
black 95 gt
I have put it on the scanner and codes are eca code and o2 sensors running lean/low voltage I have changed the ccrm and ecm
Bossman
What has been stated above and...
On the alternator test... I just changed one in my Ranger I knew was giving me problems, but it was intermittent. The tester Vatozone used is only for a very very short window of time. Anyways I changed it, and the voltage dipping went away. I also changed my battery as well.
Check your grounds for corrosion and loose bolts.
B
black 95 gt
I will change the coil in the morning and the alternator on Friday (payday) thank you all for your advise I will post what happens Nd the progress
Mrstangerbanger
Check all your grounds also .. A code reader and a diagnostic machine are way different bro .. A D machine will tell you exactly what is wrong in seconds they cost 5,000 plus dollars and will tell you the data for every sensor in your car .. Find a snap on mt2500 or solus pro
B
black 95 gt
changed the coil still has a miss i will go and have the scanner done tomorrow will post the outcome thank you all
RichV
CO
Unplug the harness right under the oil filter. It will run without O2s.
But it will run rich if the sensors are unplugged.
Also, have you cleaned the maf. often times the k/n filter will deposit oil on the maf, then the dirty maf will not send the right sign to the computer.
I find it interesting everyones recomendations when all we know about the problem is in the title and so vague.... its amazing what can happen here when there is a more comple list of what happened, what didn't happen or what you expect to happen rather then a list of parts exchanged.
B
black 95 gt
had it on a hand held snap on code reader and the code 212 came up loss of diagnostic monitor (idm) signal short to ground in spark output (spout) circuit. I DONT UNDERSTAND
B
black 95 gt
drove the mustang today after clearing the codes and letting it sit for two days and i let it warm up in the driveway temp got to about 200 (195) thermostat, drove it about 2miles temp starting rising (getting on the throttle here and there ) get on freeway another 2 or 3 miles temp was at 230 check engine light came on starting pinging at about 2200 rpms in 4th gear so i pulled over waited a few minutes and checked the codes codes 176/181/189/172/and 212 came up telling me its running lean I dont understand everything has been changed except fuel injectors , tps , and air bypass valve i can change the parts just dont know how to diagnose and i am not giving up lol any ideas AND THANK YOU ALL VERY MUCH FOR YOUR HELP
when I had those codes it was from a dirty MAF. If you already cleaned it then maybe there is some way to test the ohms of the filament.
Cooling- change your thermo to a 180* and flush your rad while your at it.
B
black 95 gt
I just put it back from a 180 and the fan on the key and I have a brand new stock radiator
Which way did you put the thermostat in? spring up or spring down? i have to ask.
When you burped the rad, did you see coolant flowing? is the fan kicking on?
