fuel pump
96sn95gt
ok my 96 gt 4.6's fuel pump noisey i think thats normal what im asking is when my blinkers are on the pump blinks with it what could that be a weak pump or short
DropTopPony
South Jersey
Punctuation is your friend :)]
Sounds like you have a short somewhere or your electrical system isn't providing enough juice :dunno:
My pump is loud but it never fluctuates with any kind of power draw.
96sn95gt
ok if i take off slowly its ok but if i step on it it bogs out :as i let off it accelerates but if my ac is on it bogs and back fires ill try to put up a vid tomorrow for you guys these r my mods if it helps :bbk cai,bbk 75 tb,anb plenum,pi intake,bbk headers and h pipe, 373's
GDTrumbo
Nashville, TN
I thought previously you had maybe a weak alt and in turn a weak
ignition system. But if the system "pulses", it could still be...
No CEL codes being thrown? I take it...no
I'm good until the backfire issue. That needs to be resolved.
Could be some unmetered air comming in somewhere. I'd check
gaskets at the TB/plenum/intake interfaces and any hoses involving
vacuum to these parts.
Then there is the PI intake. If this is set on a pair of nPI heads(as
I'm assuming here), this intake port mismatch is known to work well
in many cases. Some complain of low-end hesitations, lean conditions,
vacuum leaks @ intake/head seal, etc. You've probably heard all this.
I almost did the PI intake when mine cracked, but backed out. That'll
have to wait until I do the whole PI swap.
Surely someone with more experience with this kind of intake combo
will chime in and help. I just don't wanna send you on a wild goose
chase. But, that's where I'd start.
Good Luck. GT
96sn95gt
thanks ive done the intake 4 times, first no then 2nd it ran bad a$$ but then it went to h$ll and now this maby i should go back to the none pi
scarface
Guest
take some carb cleaner and spray around the intake ports to see if it is a vacuum leak. Plenty of people have done the PI intake swap with no issues, it could just be an install error.
96sn95gt
From the second to third time i changed manifolds,did that no rise in rpm,i think it is cracked in the coolant to cylinder part , i got it from this shop put it on went out explained what was happening and this kid said that if it was the same shop that swapped his out to put on a p51 then it may be cause the shop told him it was. i asked and they said they don't know if that was the one. Sucks that my experience with this swap is so crappy. The reason for manifold change was the first manifold was broken at the neck of the heater hose tried to fix but i cracked down to the bolt hole!
GDTrumbo
Nashville, TN
My OEM intake first started leaking at the heater hose fitting near the pass. rear of the intake.
Repaired that w/ JB Weld. Held for a while. Goosed it one day about a mile from home and the
coolant smell & steam ensued. Limped home. Cracked right behind the alt. Wasn't too suprized.
GT
96sn95gt
ok no more back fire it was a loose plug wire number 8 but i noticed that if i turn on the ac my voltmeter (stock) drops down by the 8 like around ten then if i take off it runs like sh@#$ until the rpms rise does this sound like the alternator
96sn95gt
low?like bad?should i change it first? it is a cheap on from advance auto parts (came with the car) but i got a brand new one in my vert. i didn't know if it would kill the battery ,then id have two bad batteries
GDTrumbo
Nashville, TN
Remove the alt. and have it tested @ A-Zone or somewhere.
If you replace it there, get their "lifetime warranty" part.
Personally, there are some things I will always go back to Ford for though.
Like alternators, starters, PS pump, sensors, etc. Unless I know who the
OEM's are like the Bosch O2 sensors. Got those at Advance Auto for $57 a pop.
GT
