Headlight help
916_5.0
Ok so i just got my black beauties in the mail today, i installed them today but they dont seem to be sitting very well. The driver has a fairly big gap in the corner pointing towards the grill area. And im not sure how to fix it. And the actual corner piece seems to be sitting fairly low cause there is a gap between the rubber seal on the corner and the fender. But they seem to be sitting pretty even on the bottom along the bumper.
The passenger side is a bit worse the corner light has a bout a 3/4 inch gap between the rubber seal and the fender. Im not sure if my fender may need to be adjusted on this side cause it has a pretty big gap. Anyways i was just hoping for some help on getting them set in even.
916_5.0
Yeah that gap is nasty its right at the end of the fender at the point that lines up with the end of the hood. Its the worse right were the rubber seal ends and that point on the fender is. As far as the beam you mean the headlight beam? they are both pretty even but are aiming pretty low to the ground so it doesnt light up to much of the road in front of me.
302StangGirl
... Mine didn't line up when I got them... I got mad and kicked them into place and everything worked out happily ever after for me...
916_5.0
Lol yeah i dont think i will be doing that the last pair of lights i had i was getting upset with these issues and gave them a few swift blows from my knee and broke off all the adjusters and cracked the housing.
