So Im still having this studdering problem with my car..when I start it up, it runs fine..after a min or two though if I go and drive it itll feel like its misfiring. I give it gas and it just honestly feels like its running out of fuel. However if I get off the gas then back into it it stops..
Today I changed..
Fuel Filter
Ignition coil
Spark plug wires
(Plugs are good)
And made sure fuel pressure is at 42 off vacuum. It has a BBK fuel pressure regulator..is it possible that is just bad?
Also what makes no sense is we noticed my TPS sensor was unplugged but its still running the same as it was before. We noticed that the black wire going into the throttlebody area is frayed pretty good..so I'm gonna change that in the next few days.
Does my car need bigger injectors? (mods in sig) It has stock 19# on it now. Im running out of ideas as to why its doing this..
I dont think its the fuel pump..it seems to be getting good pressure. Idk. Im running out of ideas.
Today I changed..
Fuel Filter
Ignition coil
Spark plug wires
(Plugs are good)
