HELP ! Clutch Pedal Hard After Install
Edub400
Washington, DC
Yesterday I installed a UPR clutch cable kit, and now my pedal is super stiff. I pretty much would have to stand on it to get the pedal to get down. What could be the problem.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
How tight is you adjustment? Make sure it's not too tight. Other than that, unhook the cable on top and bottom and pull it by hand and see how smooth the cable slides inside
E
Edub400
Washington, DC
Every when i had no adjustment it was still very tough to push its impossible to push this with your hand. Are the washers on the quadrant suppose to be on this side.
I put washers on the inside also, just to keep the quadrant centered. What I was trying to figure out though, if you disconnect the cable from the pedal and the transmission can you move the cable by itself smoothly inside its case? We are trying to see if the cable is free and smooth or if it is dragging and making the pedal hard to push.
It also looks like your quadrant is dragging on the insulation at the top. Cut that stuff out of there and make sure nothing is in its way.
E
Edub400
Washington, DC
yea the cable moves good without being connected to the trans. It may be that the washers are not align correct.
E
Edub400
Washington, DC
A buddy of mine said it could be the throwout bearing, since i changed everything and still seeing the same problem.
COULD SOMEONE SHOW ME SOME PICS OF THE WAY THEIR CABLE IS ROUTED.
E
Edub400
Washington, DC
Ok. Guys so today i went out re-routed the Cable and before I hooked it to the transmission I went to press in the clutch pedal. The pedal basicly went stright down to the floor with no force. Which would make me think there is no BLINDS.
But the second we get in hooked up the the fork, I go and press in the clutch pedal and it just seems hard like to hard for me to press which sitting down really.
Any Ideas ?
evilcw311
Most Evil Member!
Louisville, KY
Definitely sounds like an issue from within the tranny like either the arm is off or or something is not lined up right.
^ Im with these guys. The arm might be of the pivot ball or the throwout bearing is all goofed up. I know this is a bunch of hassle, but can you take the cable off the transmission arm and move it back and forth freely? It wont be a whole lot of movement but you will have some. Look at the arm as you move it, you should be able to tell if the arm is off the pivot ball. If it moves nice and free and looks good, it might be a clutch issue.
Musturd
My guess is the input shaft bearing retainer is messed up along with the throw out bearing
E
Edub400
Washington, DC
Thats what I was thinking as I continue my search, can't find any place that sell this for a 96 GT Why ? There everywhere for the FOX and 95-SN95
E
Edub400
Washington, DC
when i take the cable off the fork there is a little movement ( front - back) but nothing major.
E
Edub400
Washington, DC
COULD SOMEONE SHOW ME SOME PICS OF THE WAY A SN95 CLUTCH CABLE IS ROUTED. ? :sad5:
I'll see if I can dig up a picture of mine. I know the routing doesn't matter a whole lot as long as there are no kinks in the cable.
senior001
