help gt40 explorer manifold bolts up but pro products elbow and egr dont?
SouthSide Tay
ok so i got a 95 5.0 5 speed and i did the explorer intake manifold swap the prblem that im having now is that the elbow doesnt fit the upper intake nor does the egr bolt up what am i missing or what am i doing wrong thanks in advance for your help?
white95
Apex Junky
Admin
Prairieville, LA
i dont have a solution but I'm going to attempt the same swap today, I'll let you know how I fare!!!
SouthSide Tay
finally got the performance products elbow to fit with some beating and banging but overall everything fit including egr and the quality of the elbow is superb
white95
Apex Junky
Admin
Prairieville, LA
I'm sorry I didn't follow up here... one of the holes on my elbow [edelbrock] was threaded so I had to make a stud and thread a nut onto it slowly as I let it settle into place. the other three were simple. to make matters worse, it was the hole under the elbow [closest to the IAC valve] that was the problem.... I'm glad to hear you got it all together finally!!!
1bad95
Does it all just bolt on pretty much no other changes needed? I am planning on buying one here soon and just wondering what i need to prepare myself for when i get it
95-stang
Bolt on is'nt always as it sounds, they should add "bolts on......... eventually"
