Help me Identify these 2 thing please.
killagt
They both are on the passenger side, the rubber rip apart is happent both driver and passenger, and the red color leak is only on the passenger side.
can you guys tell me wat those is and how to fix it ? if the pix is too big, my bad, it look small on my 24inch lcd :D.
1998 Ford Mustang GT 147k miles, manual t-45.
forcefed5pt0
charlotte nc
top one is a lower ball joint, lower is spring and bellows boot ( or a rack boot ), if you got fluid on you spring, check you strut to see if that isnt the cause.
justinschmidt1
replacing ball joints on our cars sucks...its basically pressed in...I would get it done somewhere, dont waste your time.
94 DropTop
Or you could just buy some cobra control arms. Just a thought. It would most likely be cheaper than having someone doing it.
HISSIN50
I agree that the Terminator LCAs are a deal.
But if you wanna replace the BJ's, you can 'loan out' a tool from the parts store to do it. It's not a bad swap (I do them with the LCA on the car).
As noted, the end seal on your rack is leaking. It's generally better money to get a fresh rack (most parts store racks will include inner tie rods). You can get new outer tie rods if you like, and you'll need an alignment afterwards. Dont forget to get some decent rack bushings. I've been using poly lately.
Good luck with it all.
Dude a reasonable set of ball joints will run you about $110,for as much just get new 03 cobra A-arms. they are no more than $140 new and shipped.
IMO you might aswell just upgrade.
K
killagt
it came with both ? link please.
call these guys
at 1-800-328-9552 ask for Steve or Mike M.
K
killagt
call these guys
I english is bad, I cant have a good conversation on the phone :crying:. btw cobra and 98 gt have the same low control arm ? i mean they fix the same ?
these any good ?
http://cgi.ebay.com/ebaymotors/NEW-...011QQitemZ320271454532QQrdZ1QQsspagenameZWDVW
