Help on wheels selection!
96PonyGT
well i think im going with 17 but its the width that im having trouble with, maybe i'll just get 17x9's all the way around just to make sure
96PonyGT
another thing im iffy on is that I have 4.10s and if I get a nitto 555r 315 will I break my axels under hard launches?
Jrgunn5150
Not with your current mods. Obviously if you keep pouring in power eventually you will exceed the capabilities of the stock part's though.
For me it was with a set of stage II heads, cams, and a Paxton Novi 2200 set at 10 psi, I twisted them like a pretzel, on the street.
96PonyGT
yeah so what did you do about fixing it, is it worth it to get stronger 28? or how do you do 31 spline? I have no idea about rear ends really
Jrgunn5150
I went to forged 31 spline axles and an Eaton Pro diff with 4.30's. If I wanted a super rearend like Jeff's(Dalamar), I would have the tubes welded, 9" end's put on, 31 spline axles and a Detroit Truetrac diff. Along with a T/A performace diff cover. But that's overkill for most.
96PonyGT
yea, that sounds like alot of money and I have no clue about rear ends. i will look into it
danroadking
I like my wheels, go Steeda’s or Cobra’s
voidfinger
man i really like those steeda's. I'm thinking of going with steeda wheels on mine. Super light too right?
96PonyGT
im not sure about how light they are, sure they are pretty decent tho, and anything is better then the pony rims!!
voidfinger
i know steeda has light forging or something that suppose to cut a lotttt of weight. Weight makes a big difference for wheels.
Jrgunn5150
To add a lil something here. I've found that the "real" brands like BFG, Goodyear, Firestone, etc are closer to their staded size, width and height, than the no name brands like Nexum
