HELP SMOG PUMP DELETE
so the red dots your going to use some bolts to plug the smog ports on the back of the heads
back of engine
Y
Yellow95
unfortunately i don’t have means of pulling an engine currently but i’ll try my best to do it inside the car
Y
Yellow95
honestly i don’t need more than necessary, i just need the car running for a few mins at least, i gotta say i appreciate all of the information from all of you guys :)
Terrorist 5.0
I am not sure what the belt length would be with the stock crank pulley, but with my smaller size crank pulley, the belt length I used with a stock accessory drive without the smog pump, was 2226mm in length, although it was a bit on the longer side if I remember correctly. With a stock crank pulley, it would be a little longer. If I were you, drive your car to a parts store, go inside and pick up a couple belts, and try them on in the parking lot, excluding the smog pump. Once you find the right size, buy it, go home and yank the smog pump out.
