Heres my winter/spring project:
97stanger
So for the end of winter/early spring i plan on finishing up my suspension. I already have MM full length subframes (welded in), KYB AGX 8 way adjustable gas shocks/struts, eibach pro kit. Here is what will be installing:
MM chrome plated caster cambers
Steeda aluminum non adjustable lower control arms
Steeda adjustable upper control arms
SMR torque box reinforcement kit
Only thing im waiting on is my Steeda strut tower brace.
Anything else you guys can think of that will help my suspension out besides some sticky tires??
SRT Handz
sway bars make a Huge difference, the will make any stang handle like a go kart
voidfinger
sweet dude. I would do some sways too. I know steeda has some nice units ... for drag and track.
97stanger
97stanger
now when you say sway bar...should i look into changing my front or rear?
97stanger
97stanger
now would it be necessary to get an adjustable rear sway bar or just a tubular heavy duty one?
97stanger
97stanger
yeah im a little lost come all this suspension stuff. I pretty much know the basics...but that just doesn't cut it. :santa_afro:
Jrgunn5150
Adjustable rear anti-ROLL bar's are for drag car's, wouldn't help handling, would help hook.
voidfinger
roger roger... looks like thats what i need... plus one of those flexy ones that steeda sells for drag racing.
Steven
SC
keep the stock uppers, loose the adjustable UCA's.. they'll bind and rip your control arm out. Seen it happen
I already explained that :santa_lipsrsealed: :p
Steven
SC
just positive reinforcement :D
Steven
SC
the only upper control arm i'd run is the ford racing one, as they have the oval holes and they flex correctly. Most aftermarkets don't flex enough to make up for the design flaw in the rear end geometry, therefore causing bind and making you cry :santa_smiley:
97stanger
97stanger
im not ditching the uppers. I'm going to set the pinion angle and be happy with how my setup hooks. :santa_afro:
