i need some advice
96sn95gt
ok my cars passenger header came loose! what do i need to do to put it back on? its a bbk shorty. i know i need to take off the h pipe, but what about the ac compressor?
96sn95gt
wow! hang here i dont have a lift :crying: just two ramps and a jack,any other way? :TY:
9psi 98
Try getting at them with an assortment of ratchets, wrenches, extentions, and swivels. I don't see why you would need to drop the K member, that is just so you can get them in there easier. Worst case scenario, undo one motor mount and jack the engine up from where the oil pan meets the block. That will give you more room.
96sn95gt
do i need to disconnect the ac compressor to lift the motor high enough to get to the header?
9psi 98
trial and error. Just do it, if something gets in the way remove it.
