idle troubles...
1996mustangGT
so...whenever im at a stop now my car starts idling reeallly funny...
it will drop real low and then kick back up to where it normally idle's at..?
also when it drops down i mean it drops...if almost feels like i have a crazy cam in it or something.
so i have no idea whats wrong with it but the way ive abused it im thinking im gonna have
an engine swap coming soon....any ideas guys?
:TY:
timothy
N2Otorious
Sounds like your IAC(Idle Air Control valve) is dirty and needs to be cleaned. :thumb:
moot09
ya minedoes the same thing. i hope its the IAC wheres it located at?
atrainsgt
Mine does the same thing :rollinglaugh: Pretty sure its the IAC I just haven't got to it yet. Maybe tonight.
2REDSTANGS
I have that problem so to clean this IAC do you have to take it off? Just wipe it out while its on there? I have no idea on a techniqe to clean it advice would be awesome :TY:
atrainsgt
I just got done cleaning mine, I pulled it off and took a look at it, strange no carbon on it at all. So I sprayed it with some carb cleaner and wiped it out as best I could, shook it off then cleaned out the plenum hole with some carb cleaner, got quite a bit of carbon out of there. I will let you all know how it behaves tomorrow. Probably should clean my EGR also.
vermilion
maryland
id use carb choke cleaner. no residue. and clean your maf too with maf cleaner. on these cars its usually a combination of things other than just 1.
atrainsgt
I couldn't tell much difference with mine except the idle never dropped down lower than it should, so I guess thats a good thing. The idle still likes to linger while cruising not sure what causes that. I got a few other things to clean out, I'm not worried about it.
Jrgunn5150
Fords lame o IAC gasket causes hanging idle, there's a mod you can do to drop it quicker, search this forum. It's a few pages back.
atrainsgt
Yeah, I'm trying to decide if I want to use the 1/2" pipe cap idea or make the custom gasket. I'm leaning towards the pipe cap.
