Instrument cluster fitment help
Dirtcar75
Will a newer cluster with the digital odo out of a 99-04 car work in a 95? Thanks dj
Dirtcar75
Well ours is mexhanical but its mechanical in the cluster there is no physical connection between the trans and the cluster it just uses a motor to turn the odo and trip so if the newer cluster is a self contained unit ( the mileage and such is stores in the cluster) and the plugs are the same i sont see why it wouldnt work.... I just dont wanna buy one to try it tho lol
det_riot
Dearborn
Because our clusters are mechanical in the gauge. The feed that it gets,tells the motor to turn and the rest is done by gears. The 99-04 gets their feed from the computer I believe and it tells it what numbers to display not to turn the motor
Sent from my DROID RAZR using Tapatalk 2
Dirtcar75
Ok i guess where can i get a reman cluster? Mine the temp gauge dont work and the odo/trip dont work either
94RedGt
Hialeah, Florida
Just go to a junkyard and pull it from a v6 car, when i was looking for an odo gear I hit jackpot when i found an all stock 95 GT with around 90000 wich had already aftermarket odo gears, i felt bad for the car , who the hell junks a GT like that.
