Latest Modifications....
GaryG
where'd u get that piece for the trans temp gauge?
looks good btw
Mr Jones 4.6
We just took a dremel and started cutting out a hole til it fit and then behind the bezel, the was a little area of the dash itself that needed to be trimmed just to make things fit. Now its good.
Thanks
Mr Jones 4.6
I put the sending unit in the pan. I talked to Circle-D and they said to install it using a drain plug from B&M. I installed it in the back driver's side corner of the pan, which actually has a flat spot instead of the pan rounding off for the transition to the rear. So far it works awesome!!!
Thanks guys, I really how the location of the gauge turned out.
