Lets Talk About A/C!!! I have a question
94 DropTop
if you think you have a leak. Just buy a can that has the freon and stop leak in it.
SRT Handz
I was throwing some terms into google and some people say that the stop leak messes up the A/C system from the inside.
any comments on this?
BigTang
if you continuously use the stop leak as a solution to a large problem you will lock up the compressor. if you use the stop leak recharge kit 1 time and only use 1/2 of that can you'll be ok.
If you break the seal on the unit you will need to replace the drier and the orifice tube(like a small filter) and take it somewhere so they can pull a vacuum and recharge it.
does the compressor seem to run a lot does it cycle on and off a lot?
if it was mine i'd buy the refill w/ the dye in it so you can find the leak and replace that hose/fitting, etc. AC stuff is extremely easy to work on but its just as easy to f-it up.
SRT Handz
Any Brands of These kits that are better than the others?
i went to the Auto Parts place and they had a bunch with gauges for like $30
i was thinking the best deal would be found at wal-mart....
BigTang
i've used the blue and white can from walmart w/ the small gauge on it w/ a blue hose. it was about $20. worked ok.
SRT Handz
If i buy one with the gauge can i use the gauge to test how much Freon i have in the car BEFORE I put more in?
justinschmidt1
You need the gauge cause it needs to be at a certain PSI....
Try recharging it with a can before wasting time anywhere else.
I tihnk the gauge tells you before you crack open the can, been awhile since i did it. I got mine from walmart
94 DropTop
It depends. As long as your ac is running when you plug the guage in it should give you a reading.
g36 monkey
Orlando, Fl
Just did this a few days ago on my girlfriends truck. Extremely easy. We however just bought the part store brand cans, same amount for half the price, and I already had the hoses but they had those for sale as well. However, if you all are scared of store brands, thats your own deal ha
SRT Handz
Just got back from Wal-Mart, picked up the HUGE can of "Arctic Freeze" with gauge and what-not. $21....$9 cheaper than pep-boys.
gonna do this Wednesday, MAYBE tomorrow if i have time.
will up date once i am done sometime within the next 2 days.
SRT Handz
Just too Confirm, the "Low Side" of the air con in on the right upper corner of the engine bay towards the firewall correct?
If you have time? Its seriously 5-10 mins top, depending on how long it takes you to get your hood up.
Go do it, do it now.
SRT Handz
once someone confirms which is the Low Side of the system then i will go outside and do it now.
SRT Handz
well, i went outside to try and recharge the system but i am unsure how hard to push this snap connector onto the Low Side Pressure Fitting. I am guessing the pin inside the coupler on Charge can needs to push the ball down on the Low side pressure fitting am i correct?
i just dont wanna break the damn thing.
I don't know if anyone mentioned it but I believe when you charge the AC the engine should be running with the control set to MAX A/C.
