For Sale lots of parts high performance, OHIO
full force
Lots of parts here still.... big stuff pic up only, 44138 Ohio....will ship smaller items....most items can ship....
text 440-476-4114 for pics or I will add as I can,....
Complete 393W engine, Scat crank and rods, Ross pistons Trick Flow heads and intake, Comp cam, Comp roller rockers and more.... 5500.00 picked up
1] T56 with 26 spline input shaft, 30 spline viper output, MGW shifter, no miles since new 5th gear and a going over to make sure good, 1900.00 picked up
2] 96 Cobra 160 mph speedometer cluster 150.00
3] 04 GT 150 mph cluster 80.00
4] 96-98 Cobra rear bumper cover 250.00
5] tan 96 Cobra airbags 235.00
6] tan leather seats MINT shape 700.00 P/U
7] Tan Mach door panels 94-98 120.00
8] Tan leather steering wheel near mint, few small scuffs 260.00
9] Fluidyne radiator 94-95 with electric fan 275.00
10] Complete Aeromotive fuel system 86-95 1000.00
11] Cobra front brake conversion with spindles and hubs,375.00
12] built 96 Cobra 8.8 rear end, 3:73 gears, Eaton 31 spline diff, Superior axles, summit diff cover clean 60,000 mile housing 900.00 P/U
13] Steeda Aluminum lower control arms 150.00
14] Steeda Adjustable upper contraol arms 120.00
15] Steeda lowering springs 94-04 165.00
16] Tokico allumina shocks and struts one adjuster messed up a little was still working, 225.00
17] Tokico D spec shocks and struts paint scraped from coil overs otherwise fine, 350.00
18] 94-95 Cobra trunk lid brand new 250.00 P/U
19] 94-95 OEM Cobra wing 200.00
20] Centerforce dual friction clutch, 10.5" 10 spline approx 100 miles 250.00
21] Ram HD clutch,10.5" just bolted on never used 26 spline 200.00
22] 5.0-5.8 billet steel flywheel 28OZ weight, can get a 50OZ if needed 150.00 I have 2 of these, one is SPEC< other is FOrd Motorsport..
23] Pro FLow mass air meter 36LB injector S/C 200.00 with filter
24] Bassani 2V mid length headers 250.00
25] Bassani mid length X pipe with high flow cats 200.00
26] 03-04 Cobra fuel tank no hat or pumps 150.00
27] 03-04 Fuel tank filler neck 65.00
28] 03-04 Cobra iron block, just block 200.00
29] 94-98 trunk lids with wings 100.00 P/U
30] 94-98 GT front cover and headlight support 125.00
31] 94-98 doors 80.00 each P/U
32] 94-98 fenders 80.00 each P/U
33] Above door pillar trim 30.00 a side
34] C pillar trim 30.00 a side
35] 94-98 rear covers GT 75.00 P/U
still many other parts here I did not list, mostly 94-98.... ask I have bins full of parts....
jeanfltns01
