Low drag setup?
sleepn_sn95
Indy
I'm looking to get a better launch while still having a low stance. I plan on getting front coilovers with 175lb 12'' springs, MM c/c plates, Lakewood 70/30 struts, 50/50 shocks, and MM adjustable rear lower control arms. I am confused on what rear spring to run. I do not want to use any cut springs or coilovers for the rear. Any suggestions? Thanks
duff daddy
I cut my best time on a stock rear spring. I cut 1 coil off the top and was about the same 1.62 to 1.66 on different days. Moroso has drag spring so doesnt eibach (with air bag). The front springs and strut choice may be a little off. Most people run a 175 with a 90/10 or a 150 with a 90/10. (I happen to have a set of used 90/10's for sale) I have aftco' springs in my front end both 175 and 150 rate (same height @ 14")
sleepn_sn95
sleepn_sn95
Indy
Off topic but do you know anything about X2C coilovers? I found a guy selling 14'' 175lb x2c coilovers with 90/10 struts and was wondering about the quality
KAOSS
I launch hard with Eibach pro drag springs in the rear. For the lower control arms, Get some UMI lift bars. You won't be sorry.
