Lower door hinge replacement
carbuff
Hi, I will be replacing my DS lower door hinge soon. I know how to do it but I just had a few questions. Will I have to remove the interior kick panel to access the one bolt from the inside of the car? And are all the other bolts accessible through the wheel well with the door closed once I remove the inner fender skirt and lower fender trim? I plan on removing the inside bolt first, closing the door and then doing the rest through the wheel well and not opening the door again until the new one is in with 4 bolts. Does this sound feasible?
rz5.0
Great state of TEXAS
When i replaced mine.. I pulled the fenders off.. You do have to remove the kick panel and move some plugs out the way.. There its a nut that needs to come of from the inside..
