makes no sense
95cvgt
well i got my full exhaust in finally! :headbang: so i decided while i was in there i would go ahead and delete the smog pump while i was at it. well i removed all the lines and hoses from the pump and got them outta the bay, then i removed the 2 bolts the hold the smog pump to the pulley bracket and was ready for it to just come right off. but no. i always have to have the worst luck with cars. so ive spent the last 2 hours trying to work that thing back and forth, up and down, and which ever other direction i can manage to move it and still no luck. it looks like where the buttom stud bolt in, there is a sleeve or something that guides it all the way through. and i couldnt find anyway to get the sleeve outta there.
any suggestions, this thing is being a real PITA.
thanks for all the help in advance guys
x182dan
You could just leave it there, the only advantage of removing it would be the weight. Just get a shorter belt and bypass it.
eliyarbrough
Nocona, TX
I bought the smog pump delete thing from UPR. The reason I deleted mine was nothing to do with the weight. Like a year after I bought my car, the smog pump locked up so it snapped my serpentine belt. No prob, the next time it left me stranded for about 2 hrs. I then thought it would not do this a 3rd time. Because I bought that pulley, it used the same belt. I think.
95cvgt
i was thinking about just leaving it there if i couldnt find a way to get it off. its pretty strange. cuz the alternator just slides right off but the SP has to be a major pain. guess ill keep finding a way.
feel free to keep throwing suggestions at me. i want the hunk of junk outta the way!
95mstng
i had the same problem when i deleted my smog. u can try to it on the car or remove the whole alt. bracket to do this, but take a rubber mallet and pound it out. its easier to do off the car. u should definetly take it off it looks cleaner and it saves a few pounds.
x182dan
My car did the same thing. I happened to be real close to home so I made it there no problem. Just got the shorter belt the next day and drove it with all the smog crap still attached.
Dan
mic_lx
Dan
[/quote]
And you still get a CEL light?
BlkoutGT
MO
I remeber I had a similar problem. I ended up taking a cut off wheel to that S.O.B sleeve. Problem solved.lol
x182dan
Dan
[/quote]
no I never said anything about a CEL
Yellow94gt
Mine did the same thing... it won't just drop out... I took a BFH to it, and then it dropped right out... haha.
95cvgt
thanks for all the help guys. finally got it out. i would just wiggle it and look at it then wiggle it some more. wondering why it wasnt moving(which it really was. haha) so i shut my hood to take a break for a little while and, clunk, it fell right out for me! lol
sn95turbo
lol luckily my SP came out with no problem. But it is funny that it just fell out after closing your hood.
