Mass Air Meter
Mbachota97
I was told to buy a lightning Mass is there anything else i need to buy with it no? Thanks
Mbachota97
i dont need the adapter plate or the plug just the meter. Im just making sure before i buy. Thanks
9psi 98
scarface said:
90mm LMAF will work fine, just plugs right up
It comes from the factory calibrated for 42# injectors, that won't screw anything up if you're not running 42's?
scarface
if you change MAFs you need to change your tune anyway.
9psi 98
You and I know that, but the average consumer doesn't know that there's a little more to do than simply plugging it in and mounting it.
scarface
Gotcha, I see where you were going with your statement now O0
alleghenyamerican
