Need clutch help asap
ivan12
I just put in a new clutch and my flywheel was resurfaced. But I noticed there's some play in the clutch pedal. Is there a way to adjust the slack on the stock cable?
Slinger
not with the stock clutch cable,it should be auto adjusting.you will have to buy a firewall adjuster to fix ur problem most likely
LAFENATU
The stock cable is self adjusting. You probably need a new cable..is it the original one?
I like the stock cable myself, I replaced my 92 cable with another stock one, worked great.
duff daddy
I know with modulars and pushrods are prob the same, Ford Oe cables are THE BEST for a replacement.
ivan12
ivan12
I was thinking of going OEM, but I might get a MM unit instead, it's roughly the same price but comes with the quadrant and adjuster. I pulled the plastic on the firewall so I could pull the cable, the gears go in but I have to slam them in. Not only that but the car runs a bit funny, like it's lacking some umph. I hope it's just a clutch thing and not the fact that I switched to synthetic oil.
bama 94gt
I always just get in the car and pull the pedal up that how i was told to adjusted it but idk
LAFENATU
That would have nothing to do with the car lagging homey.
