I would do O2's before dizzy. The motor runs, it just pings like mad. that rules out the dizzy.
Make sure after you replaced all those components you disconnect the battery for about 10 minutes. Otherwise the computer will be using the old info that was stored from before.
Do these cars have 2 or 4 sensors? And if 4 would you replace all 4 or just te front two? Also where is the exm ground? Also it pings like crasy but now it has that high rpm miss and te tach is acting screwy and someone said it gets its signal from the dizzyand its pretty hard to turn when its put of the enginethats why i was approching the dizz beeing bad
