Need some help!
SVTSnake955
ok i took the top of my manifold off to clean it up and repaint it and i just put it all back together and now my car is running different and it almost sounds like its camming and then when i shut it off it lets out a pisssssssssst sound like its letting air out of somewhere does anyone have any idea what this could be?????
SVTSnake955
thats what i figured too but when i double checked everything its all hookd up and there is no loose vac lines anywhere
Win
Kennesaw, Ga
Take some carb cleaner and spray it around all your lines and if it revs up you have found your leak.
SVTSnake955
ok guys i looked at all the vac lines again and the only thing i can find is there is two larger vac lines that come from the back of the manifold then it goes into a T and then to a check valve.... that check valve has a strong vacuum and if i cover it with my finger the car runs better so my ? is can i just plug that up or is that supposed to be like that ??? if not why is there a vacuum on it ???
Did you plug the PCV valve back in? may be it's clogged? open the oil cap and see if smoke comes out when you plug that "Strong" vacum line.
