New Toy
chaz
Draper UT
2003 5.4L cobra
Picked it up last week
Motors built to handle 1500hp-
-Al Pipito racing 5.4L .020 over cast iron block(swapped and installed)
-Forged pistons (Manley)
-" rods (Manley)
-" crank (forged)
-cold air, custom tunnel
-Sullivan upper and lower intake manifold
-aeromotive fuel rails
-BBK h-pipe catless
-Magnaflow catback
-kennebell boost-a-pump fuel system
Drivetrain:
-Spec stage 3+ clutch w/firewall adj.
-alluminum flywheel
-26 spline input shaft
-level 5 axleshafts with version 2 hubs
-Detroit tru-trac
-mgw shortthrow
-mgw 6spd knob
Suspension:
-MM caster/camber plates
-MM IRS Delrin Alluminum and polyurithane bushings kit
-mm coilovers (f/r) with 350lb springs
Brakes:
-hawk pads
-stainless brakelines
-4 piston cobra r brembo brakes front
-front kmember and A arms...qa1 setup
Car makes 369hp N/A
For Xmas it will be getting a single or twin turbo set up with a 12lb and 18-20lb tune
got5.0
Atlantis
I'm confused... why is it N/A right now? are you just building it for the turbo?
CompOrangeSN95
North Jersey
soldier took the words out of my fingers... that is absolutely tits man, but I have to admit I like the cobra wheels more
C
chaz
Draper UT
Cobra wheels had some scuffs so I put my wheels from my other car on until I can get a nice set or get them re-coated. I'm sure I want to go with a 10.5 in the rear so I can keep a 315 DR on the rear.
