OLD H2S
Here is a pic of the oil gallery pressure bleed off hole. It is 8mm in diameter, in the past I have made a sleeve and reduced it down to a 7mm hole, Is the good or bad? How about when running the stock oil pump with the small type gears not the new 3V high volume one with the 13mm wide gears?
