Oil pressure and highway speeds
Rolltide1006
Hello all and I apologize if this issue I am having has been answered before. I can’t find my particular issue discussed on google :( Oil is full and is Motorcraft 5w-20 with a Motorcraft oil filter. Wiring to the autometer gauge is [emoji108][emoji2532]
I have a 97 GT and hooked up a autometer oil pressure gauge to know where I am at. The motor is a 4.6 2v and has PI heads, blower cams and was rebuilt 2k miles ago. Oil pressure is 70-80psi on cold start and I never lose it or see it drastically change. When nice and hot, I am idling with 20-25 psi. Once i bump the throttle it shoots to 50 psi. When I accelerate hard from a stop I see a nice gradual climb with pressure all the way to 60-70 psi. When I am driving on the highway is when I notice a slight fluctuation. When I am going 70-75mph in 5th gear at about 2200 rpm I noticed the meter was at 50 psi. I give it throttle and the needle will drop slightly down to about 45 psi and once I let off the throttle it will jump back to 50 psi. When I am at the same speeds and drop it into 3rd and accelerate the pressure goes to 55 and doesn’t climb as quick as it does when I am messing around in town. This is my first time having a aftermarket oil pressure gauge so I may be just a little paranoid. Just wanted to hear yalls opinions and/or experiences. Am I crazy or what? Thanks in advance!
Sent from my iPhone using Tapatalk Pro
Silver95bird
Keep in.mind the Ford oil pressure light doesn't come on until about 6psi.
If you think the running pressure is low, try 5-30 like the 4.6 was originally speced for.
OLD H2S
Silver Spring Maryland
The new Ford Mustang oil is 50 weight...think Ford finallly said screw gas mileage, no more warranties.
BTW after killing a new motor in 10 miles with 5-20. I started to look at thicker oils and the new Ford popped up and the BMW 60 weight is out there, so the old BS about tight engine tolerances is just that.
I really really liked that engine I killed and your numbers are the same as mine running a high flow MMR Hurricane pump with billet gears.
Rolltide1006
Rolltide1006
How did you kill the motor in 10 miles using 5w-20?
01yellercobra
Got jumped by a Porsche and had to beat him up...do stupid stuff win stupid prizes. See it never goes away, even when your in your 60's.
Is that the engine that died in 10 miles? I'd say you had another issue creepin up on you. Jumping on it just accelerated the outcome. I ran 5w-20 for a break in oil in my big bore stroker. It saw full boost within 20 minutes of first start up. Never had an oiling problem with that engine.
OLD H2S
Well if you follow my build threads, I just finished engine build number 13. Some of them were just tear downs to see how a particular part or idea was working. That engine that had a rod knock in 10 miles was not a perfect build but the normal type of throwing in all new bearings, rings, seals and that was build number 4 on that block so I was surprised to have a rod knock so fast. I would have to dig through my notes to tell you if it was a King bearing or Clevite and which series because I was trying all different types and that is one off the reasons for the tear downs is to see what is advertising BS and what will hold up. The Ford type solid aluminum bearing is a very good design and was new at the time and has stood the test of time now but it is very hard and if any close spots are around there WILL be damage. The King bearings come in softer compounds and get harder for higher HP and for rebuilding engines the moly coated types are the best because they wear in easy without seizing and scoring.. the coatings take the hit and it is easy to see problems on tear down and inspection.
That is a lot of information right there for anyone that is building an engine if you look. I am not an engine builder but I have built many engines of all different types and have had engines last 30 minutes that were made by the big names in the business for Terminator engines. This is the reason I have started to do my own builds and you can not stand on dyno numbers, you must do tear downs to look and measure. Every time I help people with engine problems I see mistakes, that is why unmollested virgin cars now get the most money and all the car shows use crate motors on build ups, they might not be the super high end stuff we see in HotRod magazine every month but they work with no head aches. If I had to do it all over again....
OLD H2S
More info, the rod bearing that was bad was number 8 nearest the rear main bearing. This is where all the junk collects when not cleaned out when building an engine even for Ford on the first build. I have saved my original rear main in my bearing library to show people the amount of junk in a factory build. The bad bearing did not harm the crank? Now I have started to use a plus .001 rear main bearing for extra dirt clearance?
When pro's build engines for high RPM/longevity contests they run big clearances and high flow pumps and do not care if the pressure is low from big gaps.
So are big gaps or big pressure better?
01yellercobra
Most of us probably have engine builder stories. I've built a few over the years as well. My first mod motor I farmed out to be safe. I should've just built it myself as thats what ended up happening in the end. My first clue should've been when he "forgot" to order the head gaskets, but they were on the bill.
Rolltide1006
Rolltide1006
Lolol. Forgot to order head gaskets. Ya my first machine shop installed my forged rods in backwards [emoji2]
01yellercobra
I found some other things after the fact. Like there was supposed to be stainless steel rings. But he installed moly. It was an expensive lesson.
Rolltide1006
Rolltide1006
Thats no good. I know of this lesson as well lol.
Rolltide1006
Rolltide1006
Meh, this morning’s commute was crap. I was in traffic for 35 min bumper to bumper. I noticed that my oil pressure was telling me 12.5 at idle at times. When I finally got up to speed while in 5th gear i was at 40psi. I know that these readings are still in spec, but I hate how they keep getting lower :( I am going to change the oil after work today.
evilcw311
Most Evil Member!
Louisville, KY
