One Loud A55 Cobra...
ItsASleeperTillItStartsUp
It's A Video I seen At Least A Year Or Two Ago But Still Nasty...
http://www.youtube.com/watch?v=2lQX3cOAbes
03 Cobra with Kenne Bell Super Charger, Low 10's 1/4 mile and 600 + HP
1500 Hp Ford GT Walks 1000 Hp C6 Corvette
"Danny's Supercharged 1000 hp (850 wheel hp) 402ci forged motor mallett c6 corvette ran into a twin turbo ford gt that was still feeding through the supercharger. Ford GT was about 1500 hp @ the crank, guestimate would be 1200 whp on race gas (which i think it was running)."
http://www.youtube.com/watch?v=jpX8pnlvsoU
Hennessey Venom GT
http://www.youtube.com/watch?v=lnsJapPC74g
2011 Hennessey Venom GT Specifications
Performance
0 - 60 mph 2.5 sec.
1/4 Mile 9.9 sec. @ 162 mph
0 - 200 mph 15.9 sec. (Bugatti Veyron = 24.2 sec.)
Top Speed 267 mph
Power
Horsepower 1,200 bhp @ 6,500 rpm
Torque 1,155 lb-ft @ 4,200 rpm
Specific Output 166 bhp / Liter
Bhp / Weight 767.23 hp per ton or 2.61 lbs / hp
Boost 16 psi (1.1 bar)
Fuel 93 octane
Engine
Type V8
Block Aluminum
Size 376 CID (6.2 Liter)
Position Mid Longitudinal
Compression 8.8:1
Redline 7,200 rpm
Forced Induction Twin Garrett Ball Bearing Turbochargers
Oiling System Dry Sump Lubrication
Fuel System Sequential Multi-Port Electronic Fuel Injection
Transmission
Type Ricardo 6-Speed Manual
Gear Ratios 2.61:1, 1.71:1, 1.23:1, 0.94:1, 0.77:1, 0.63:1
Final Drive 3.36:1
Brakes
Calipers Brembo 6-Piston (all four corners)
Rotors 15.0 x 1.34 in. Carbon Ceramic (all four corners)
Suspension
Type KW Variant 3 Adjustable Coilover (all four corners)
Ride Height Adjustable by 2.4 inches (60 mm)
Dimensions
Length 15.27 ft. (4,655 mm)
Width 6.43 ft. (1,960 mm)
Wheelbase 110.24 in. (2,800 mm)
Track / Front 63.46 in. (1,612 mm)
Track / Rear 63.15 in. (1,604 mm)
Body
Material Carbon fiber composite except doors & roof
Type 2-door
Weights & Measures
Curb Weight 2,685 lbs (1,220 kilo)
Dry Weight 2,524 lbs (1,147 kilo)
F / R Balance 37 / 63 (empty); 44 / 56 (with driver & passenger)
Fuel Capacity 18.5 gal. (70 Liter)
Wheels & Tires
Tire / Front 255/30/20 Michelin Pilot Super Sport
Tire / Rear 345/30/20 Michelin Pilot Super Sport
Wheel / Front 9.5 x 20 in.
Wheel / Rear 13.0 x 20 in.
NCMystic
do you know what mufflers that 03 cobra has? i've been trying to figure out forever
JerZeyStangz
Northern NJ
The black cobra has mac flowpath cat-back, with VRS x-pipe if I remember correctly/The midpipe could also be a bassani. But I'm positive on the mac cat-back.
NCMystic
i have long tube headers and a 2.5(i think) catless H, would my car have the same exhaust note as the black cobra if i ran the flowpaths?
auto_x5.0
It would probably be a little quiter
Win
Kennesaw, Ga
They run forced induction with heads that flow better. You would be surprised the difference all that makes.
Stock motor just exhaust mods. Same Borla XR1 with a O/R pipe
http://www.youtube.com/watch?v=7o0NWcIOl6k
Glueyes 331 ( i think) with a built motor Same Mufflers and O/R pipe. he had a full kooks custom setup but you can tell a huge difference.
http://www.youtube.com/watch?v=BPjxk9Hv4xY&feature=channel_video_title
NCMystic
i'm in the process of putting C heads, a ported eaton and forged internals in the mystic
i had been planning on the flowmaster 10 series single chambers
that black 03 from the snake bite video does sound sick though. choices. . .
should i start a new thread about this, sorry to thread jack.
auto_x5.0
Im sure if you used your search bar up top you can find hundreds of threads about it bud
NCMystic
how could i get my soon to be supercharged 96 to have an exhaust note like that white gt?
NCMystic
they sound so restricted though. i like the hollow gravelly sound of the 10's, that's what i'm looking for
NCMystic
those have more of a burble and less of the hollow crackle i like so much out of the 10's if that makes sense at all
