So im looking to build my 98's motor. I plan on eventually boosting it in someway so im going to do all forged internals but im trying to keep this somewhat cost effective and what is going to get me the most bang for my buck. SO my question is are Aftermarket heads that cost around 2 grand really worth the extra money over the p.i.heads or are they not. I will be doing cams as well. Do people have any experiences to share? Thoughts? Advice?
At least 500 but ideally more. Ive been reading and basically if I got them and ported them and upgraded everything on them they would be just as good as the aftermarket heads. Is that correct?
A stage 3 port on a set of P.I. heads will flow the same as a set a TFS heads but by the time you do the port and upgrade the springs the price difference is only like $200 off the top of my head and the TFS has some rebuilding options that factory cast don't, also if you goals change down the road the TFS heads can still be ported to flow even better.
I bought a set of pi's from a junkyard and bought a set of carbide bits and just did some work on them myself. I am sure they aren't perfect. But both machine shops I took them to said they were decent. I did built bottom end, .020 over, wap block, cams and eddy jr intake. It runs good, but it is eating me up in the back of my head that I didn't go with some professionally built heads. And like torch said, all said and done you are in the same ball park anyway.
Some people say just turbo the car with stock heads and turbo cams and call it a day, so its all depends on what you want to do.
A set of stock heads with a few tricked out port touching (in no way you would think of a porting scenario) can handle some serious compresion, but im a n/a guy and care less about forced induction. torch318 pretty much sums it up if your wanting 500+.
When you say aftermarket heads, only Trickflow exists for 2V's. Now the PI heads I bought from Fox Lake that were their Stage 2 version are really nice but if the Trick Flows were out back then I would have went with them.
I mean I can get the P.I heads off ebay for 500 bucks total or just from a junkyard. Get them ported and do the springs and stuff and I should come out at around 1200 depending on how much the porting costs. so it would be way cheaper if I went that route. If I bought them brand new I know what you guys are saying but I figure if im getting them ported and crap then there's no point in buying new. Ill prolly just bolt the m112 on there to start. Would I need a special adapter or something for that or will it bolt right on?
You're not going to get a stage three ported head for $1200 http://www.modularheadshop.com/CylinderHeads/2VPI.aspx A m112 is not a direct swap as the four valve heads are different. You will need a conversion kit from tork tech along with other parts. http://www.allfordmustangs.com/for...wer-2-valve-4-valve-supercharger-swap-gt.html
The port cost money then you're gonna want to replace everything in the head. Valve seats seals guides springs retainers cams lifters and followers before you know it BOOM another 1500 bucks.
What do you want to spend on this build? We would be able to tell you what your budget will get you and what you could expect for power. Are you going to do the work yourself?
Yeah me and a buddy are doing it. Ideally I want to have a max of 4 grand in the motor. Cobra crank, forged pistons and rods, harp bolts, then the top end.
remember the old saying " gotta" -pay to play, first off the only aftermarket casting for modular 4.6's are trickflow heads, anything else is just a factory ported casting pi or non pi. its same with my year 5.0 pushrods, everybody wants to cut corners save money and go with factory ported gt40 heads, but by the time you do valve jobs, springs, retainers, rockers, port work shipping back and forth if you have to pay to ship them out your talking $1,000. you could of bought aluminum head that flow same or better unported and still room to port. same goes with pi heads, might aswell find a cheap pair of pi heads to do pi swap and port them if not just spend a little more and get a set of trickflow heads. hands down fastest 2 valve cars I see are either turbo or have trickflow heads. or both. that being said I stand by trickflow I run them on my pushrod 95 5.0 and love them trickflow all day. I would say trickflows if you want to keep it all motor, most of the fastest n/a 2 valve cars or dynos I'v seen have been trickflow headed combos/ and or 5.1 stroker / cars. and fastest power adder 2 valve cars ive seen have been turbo cars or ones with the torktech kits with 03 cobra blower twin screw kb / whipple or eaton setups with forged motors. But hands down 2 of most impressive 2 valve ive ever seen was a car that had a cobra block , trickflow heads forged 5.1 motor with turbo kit, thing made 650rwhp on low boost pump gas had over 800 on race. and saw a 8 sec 2 valve car was a 99+ gt with same setup 5.1 stroker forged trickflow heads a huge turbo and 25-30psi thing was running 8.80's in the 1/4 .
In most builds the supporting mods cost more than the engine build. Generally you can figure $40-$60 per hp over stock for final cost unless your very creative with part selections and run across some good deals.
If I was doing a "budget" boost build I probably would't even worry about porting the heads. Stock PI heads will get you to 400/500 rwhp with enough boost.
this is true. but sounds like your not worry about budget and 450-500hp, so if your looking for 600+ I WOULD SAY SPEND THE 2K BUY THE TRICKFLOW HEADS. LOL
I have as much money into my fasteners as I do into my lower end on one of my builds.... ARP shit adds up quick.
So Ive been looking at the bottom end stuff and found on modmax full sets of eagle forged pistons, crank, and rods they vary in price depending on options and if you want a stroker kit or not. What do you guys recommend for forged internals? Best bang for the buck, best overall, etc.
