PI Headswap question
evilcw311
Most Evil Member!
Louisville, KY
You have the right idea. Tape it up, wire wheel it, wipe it down good then paint.
sk8erord
So I started swapping over the oil galley plugs from my npi heads to my pi heads and found that the pi heads have two threaded holes that my npi heads don't. Thoughts?
Sent from my SM-G950U using Tapatalk
Silver95bird
Probably newer heads from a crown Vic? I think they added a cyl head temp sensor as a backup in later years
sk8erord
Valley and valve covers painted. Plugs moved over. Time to start assembly... Well after I coat the headers. Any advice on installing the long tubes at the same time?
I'll probably do some more engine bay cleaning before I put everything back together. Cleaned the timing cover and other components that came off already.
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
Advice for the long tubes is, good luck. Ive only done one set of long tubes with a factory k member and I bolted them to the engine before putting it in the car. Maybe you can set the header down there before you put the heads in? I dont know how accessible the bolts will be though. What kind of headers did you go with?
Now Im wondering if you can bolt the header to the head and set them down there at the same time?
sk8erord
Looks to be all sorts of room right there. Maybe bolting them to the heads first will work.....
That's pretty much what I was planning to try - test fit everything first, but wanted to see if anyone had done it. I'm pretty sure I have to disconnect the steering shaft for it, and possibly remove the starter, but I'm not 100% on that last one. Trying to figure out if the stock steering shaft will even work. I've read that I may need to get the MM steering shaft to have enough room. I might do it anyways, since I've read that the stock steering shaft sucks, and gets worse with long tubes due to the heat.
Forgot to add - I bought Pacesetter headers. BBK, et al were a bit out of budget, and I'd read decent things about the Pacesetters. Just need to strip that black paint they use and coat them. A tubular k member is in the future, so at worst, I guess I can reinstall the factory exhaust manifolds and wait on the k-member, but I'd rather not.
lwarrior1016
Staff member
South Mississippi
Why not give it a shot? Ive not done it this way but I really dont see why you cant. You will definitely need to remove the steering shaft and I would say yes to pulling the starter. You wont know if the steering shaft hits until you get it all installed.
sk8erord
That's the plan, but figured I'd check to make sure I wasn't trying to reinvent the wheel. :) Thanks!
01yellercobra
FWIW, I spoke with a guy that removed the head in his Cobra with the long tube header attached. He put it back the same way.
sk8erord
96blak54
Staff member
Lawrenceburg Kentucky
By Pi cams, you mean actual legit mustang pi cams? Cause exploders, trucks, and vics came pi heads but not all the same cams like everyone claims they are the same. The mustang cams are the best performers. In all actuality the npi cams are the best from a measurement aspect. A running cam differs greatly from a measured cam.
Seek out legit mustang pi cams
sk8erord
Apparently, in my car, it isn't going to happen. Just can't get the headers to fit in there. However, upon closer inspection, it looks like the motor mounts are shot, so I wonder if that's caused the motor to settle, so I have less clearance. Either way, I need new motor mounts. Any reason to NOT get solid mounts for a track only car? I'm thinking also, when I jack the motor up to replace the mounts, I can slip the headers in at the same time.
I did disconnect the steering shaft and the starter, but it wasn't enough. /sigh
sk8erord
And is it just me, or does no one make a transmission mount for my car?
96laseredcobra
Farmington MO
oem or aftermarket? cause my prothane polyurethane trans mount is the reason for me figuring out my rear control arm bushings are out lol.
Sent from my SM-G955U using Tapatalk
