PI intake swap
low9sGT hahajk
http://www.mustangforums.com/m_3833004/mpage_1/key_/tm.htm I'm using this writeup.
I know this swap has been covered, but I'm having some problems finding little bits of information I need.
I have the all plastic NPI intake manifold and converting to the PI intake w/ aluminum crossover.
Will I need the alternator bracket?
I thought I read that you used the NPI manifold gasket instead of the PI manifold gasket, which one?
Is this the correct parts list:
PI intake manifold
PI intake manifold gaskets
PI water coolant tube
PI water pump nipple
180 degree thermostat
thermostat gasket
EGR gasket
Coolant hose from heater core to intake manifold
16 new O-Rings for the fuel injectors
High Temp RTV sealant
waterpump o-ring
Thanks
vermilion
maryland
if you have the revised npi manifold with aluminum x-over then no. if you dont i can probably help you.
L
low9sGT hahajk
I have the NPI manifold without the aluminum crossover. I'm switching to the PI with the aluminum crossover. I'm unsure about whether my current alt. bracket can be used with the swap.
gt96stang
Yes.. You need a new alt. bracket.. I just did the swap; and I went the same as you (plastic npi--->alum. PI).. You need the bracket.
bigjohnson4.6gt
not to hijack your thread but does anyone know of a vendor that sells all the parts you need for the swap? For example just like the livernoise setup minus the intake manifold
gt96stang
no.. But i ordered all my parts from randy stinchcomb at liberty ford
410-655-2000 ext. 5618
look up custom mustangs of south florida on ebay, they have the entire kit including a tapped 2nd coolant hole. thats the guys i used, not too bad in price either. came with everything even the RTV. lemme see if i can find a link
