laramik
- Joined
- Jan 6, 2019
- Messages
- 95
- Reaction score
- 15
I didn't do that because the plugs are all new. I can do that to all with the exception of cylinders 3 and 4 because they're under where the air intake is so I can't get to then without that removed. I did however listen to each one with a stethoscope and they all sound like they are firing.. I can also swing by HF and buy a fuel pressure tester as well. As it stands it's getting re-assembled with the new FRPP PI intake today cuz I needed new gaskets since the old ones had rtv on them which wouldn't come off without destroying the gasket. So earliest I'll be able to start it is tomorrow once the rtv has cured.have you tried unplugging the spark plugs as well as the injectors? Stumbling while disconnecting the injectors tells me it has fuel but we still do not know if your missing spark on one or two cylinders.
Could any of this be because I used brake cleaner on the throttle body? And what would've caused the fuel pressure to get messed up? Just removing the lines can mess up the fuel pressure regulator?
Sent from my moto g(6) forge using Tapatalk
