Polished Cobra r help
Blakonblak94
So I posted an opinion topic in another section, and just kinda decided they needed to be repolished. Well Help a brother out. They are 17" cobra r's, I want them to shine like a mirror? Should I wetsand, then polish, then seal? Please advice, Im tired of them looking cloudy, and stained.
G
GREG@SN95
Guest
Try a polish first, if that doesn't work, try a compound, etc... Always start with less and do more only if needed
G
GREG@SN95
Guest
Blakonblak94 said:
Before or after the sanding process?
Polish, if that doesn't work...
Compound... if that don't work
wet sand 2000... if that don't work
wet sand with a coarser grit until you see results...
Why wetsand with 800 if all it needs is a good polish or compound. You would be making an hour job into a several hour job for no reason...
Always start with a light cut polish or compound before using a heavy cut compound or sand paper whether you are working with metal, paint, plastic, etc...
Blakonblak94
Blakonblak94
Will do. It may be a few because the weather isnt exactly in the condition to be working outside.
