Power seat question
Daryl
Daryl
Somis, CA
Can this be opened? If so, how?
Cancel that, got it! But now,,, how do I clean it up?
Daryl
Daryl
Somis, CA
Here’s pics of what’s inside…
Daryl
Daryl
Somis, CA
After a quick YouTube search, I cleaned off the pointy things on the picture on the right with rubbing alcohol and Q-tips. I don’t have WD-40 electrical cleaner blah blah blah and they said this was 2nd best. So I cleaned and dried them with Q-tips.
I did a very delicate, light cleaning & drying on picture on the left, plus I ever so slightly bent the little dorky things up so each pair was even and not one side pressed down.
Should this, theoretically, work now? Do I need any dilithium grease or anything like that before reassembling?
Thanks anyone/everyone who can help! Cheers!
Daryl
Daryl
Somis, CA
I feel like I did everything I could, given my limited knowledge and experience with electronics. Things actually looked clean after the rubbing alcohol. Everything went back together nicely, including the right, left, up, down toggles inside and I very slightly turned the tiny copper (?) pins in that hold the 4 individual toggles in place, careful not so snugly that they couldn’t teeter-totter.
Bottom line… I guess I just have a bad switch! Maybe Joemomma will come through. Keep ya posted!
I‘ll still take those links to eBay, etc though!! (wink wink nudge nudge)
Thanks and Cheers everyone!
cobrajeff96
Germany
No, if the internals are making good contact, it's not a bad switch. The contacts could simply be worn down from all the friction of just operating it. If that's the case, you might be able to forcefully bend them a bit so that they make solid contact again. Also check the fuse if you haven't already.
GTamas
Austria
Wouldn't it be strange if all 4 contacts would wear out at the same time? Maybe it is something with a cable or fuse, or the motor itself?
Daryl
Daryl
Somis, CA
I did that! Had same issues with the remote for my truck. Just bent the doohickeys up so they made contact again. Worked.
95opal
To be honest the best thing i did was toss the power seat crap in the trash. That crap has some weight. Might want to consider a manual seat track if you cant find what you need.
Daryl
Daryl
Somis, CA
I would be completely fine with that. Are they hard to find? And does not having the leads connected mess up any electronics or fuse box?
badass98svt
Easy to find. They are in every 94-04 V6 mustang. Do a search on eBay. It would take you just a minute or so.
No it doesn't affect the electronics.
Daryl
Daryl
Somis, CA
have we tested for power at the switch or the motor while pushing it?
Nope, but that’s next.
First off, BIG shout out to Joemomma for the seat switch. Very cool of him to relinquish that. Thanks again!
Secondly, seat still doesn’t function. And, given the fact that there are 2 new motors and switch, I’m thinking it’s the power supply or the wiring looms themselves??
Recall, earlier on I pulled every single fuse from the fuse box and all were good. That’s what (again, in my very limited electronics knowledge) leads me to think it’s the wiring. Process of elimination.
So, if anybody is willing to teach me how to check this, I’d greatly appreciate it. I do have a voltmeter but I don’t know how to use it to check wiring, etc.
Cheers!
