I believe most Clifford systems prevent the starter from cranking the engine. Does it crank and not start or is it a cranking issue. Your post would seem to indicate it's a no start and sometimes the engine shutting down when running. If that's the case there are about 3 possible causes. Failing PIP (hall effect sensor), ignition coil and ignition module (TFI). Have you tried to pull the diagnostic codes (DTCs). These codes, if present, will help narrow the search.[/QUOTE
OK, I should have provided more details. Last spring I installed an MSD system using the MSD harness no cut wires. Took it out for a spin car made it around the block, then suddenly everything shut off. I removed the MSD and the car started then did the same thing again. I parked the car and ripped the engine out for rebuild which I was planning anyway...HCI Supercharger build. I never solved the problem, stupid on my part no patience. Just prior to this I relocated the battery to the trunk and thought maybe a bad ground. I had rebuilt the distributor the summer before and the TFI module is a brand new Performance Distributors TFI. I have also installed new pillar gauges but I used fuse taps and did not cut any wires. Now it was cranking when I put the new engine but did not start. I adjusted the fuel pressure the the fuel pump stopped and no crank but the interior light is flashing, I dont have as if the immobilzer was tripped somehow.
