Problems removing the shifter
Lwiss
Quebec
Hello :)
I am having trouble taking the shifter cover off, i have unbolted everything but it seems like its stuck!
Is there something I need to remove that im not seeing?
I have a good picture here http://yfrog.com/47shifterdj
Thanks
greenscobie86
The Big Apple
No problem.. Be careful because when it pops off you don't want it to fly up and hit you in the face lol...
^ This happened to me.... :crybaby2:
ProKiller
PA
you have to pound on that guy pretty good to get it out sometimes. as long as you don't pry against the shifter lever there is nothing to break so have at it.
Don't ya hate it when you punch yerself in the face? :laughing4:
Addermk2
If you are removing it, and replacing it... just hit it with a hammer
joekd
Ct
Here's the easy way, bolt the handle back on, now pull back on the handle and it will pop right off
Leverage FTW
sn95gtvert
Spokane Washington
i've done 2 for friends, unbolt it from the trans and yank that sucka straight up. it may take a few trys but it'll pop.
i wouldnt hit it with a hammer or pry on it, maybe try a rubber mallet.
Addermk2
scaredy cat...
if it doesnt come off with a hammer.... you need a bigger hammer
i just el oh eled at work.
good stuff. lol.
they can get on there pretty tight... try and use a flat head screw driver if tugging doesnt work. ive also heard pushing sideways helps, but make sure youre in nuetaral, not a gear.
Addermk2 said:
scaredy cat...
the joys of working on a 12 year old car, eh? :p
Paul
I always give the handle a thump with a rubber mallet, and voila, it breaks the RTV seal and comes right off.
L
Lwiss
Quebec
the car was lifted so all i did was crawl under and simply push on it with a flat screw driver didnt even need to hit, i did this cuz i wasnt able to pry it apart i didnt have enough room.
