Project '' The Hooker '' *_*_* 7/19/2009
T
Tungstenizer_GT
Re: Project '' The Hooker '' Updated 5/2/09
ok, finally we got to work again, been busy with college latley and all. yesterday we made the small step which made us think were all done, lol... no were not.
I installed the trans rubber mount and trans bracket, I also installed the wheels and lowered the car, dam with this suspension she can lick the ground, lifted it around 1.5 inch for better clearance and also for registration. what where gonna do now is clean up the mess in the garage so that we can work in peace and clean. wiring , splicing and all that is the messy step and which will take lots of patience. I dont wana do the work twice so thats why am taking my time.
enjoy yesterdays pics and am gna go head to work on her now ;)
amm off now to install the following.
radiator, headers , driveshaft, buttons, shifter, hoses, x-pipe, catback and 50% of the wiring.
T
Tungstenizer_GT
well, I didn't finish what I listed for today, as we faced a huge shitty problem which was the headers touching the steering stem on the driver side. so I tried to weld off the stock headers a bit but no use, so I took off the 2v to 3v conversion brackets that I got ( only removed the drivers side ) and reinstalled the stock 05 headers. It fits great without any problems.
After that I installed the driveshaft which also took me an hour, which was the bolts being so freakin hard just for a small wrench. then I went to install the new starter motor whihc wasnt a problem thanks to the K-member being so tiny.
Installed the steering wheel and fixed the steering stem bolts and I also installed a new stock clutch cable. and I noticed that I am having a problem. later after the pics I will tell you about them.
I also got the radiators and compared each other. and I thing I am going to use the stock V6 radiator since the 05 radiator being so damn huge in tthe sn95 body.
installed the headlight buttons, traction and hazard light buttons and the info,setup buttons. yes I feel Like i did something .. haha
ohh yeah.. saw the short shifter laying around and couldn't resist the damn beauty quality, so I installed it and it is great. I had to cut through the body though for the manual trans.
now... to the fun part.. PICTURES..
http://
From 6 pm to 11 pm were working and the last meal we had was at 2:pm so we had to take a break.. BK is da bij
llol look at the difference in rads..
Ok,
the issue I came across is that when I installed the clutch cable and tested out the clutch pedal, its going in but is not coming back alone, now am sorry for being kinda dumb here but am used to the s197s hydraulic clutchs. never owned a cable clutch car before. so let me tell you.. I used a brand new clutch plate, and a brand new flywheel. but the pressure plate is off a 2005 mustang spec stage 1. could the problem be from the clutch plate ?
I hope that tomorrow I find time to install the radiator and all the hoses and then begin working on the fuse box. after the fuse box I'll be installing the pcm which will be under the passenger side fender. once those aer done I will install the steering pump and all that will be left is the exhaust and wiring the car.
Re: Project '' The Hooker '' Updated 5/16/09
you've been busy. nice work.
you'll love that ccw shifter. I've got the same one.
T
Tungstenizer_GT
Well, I worked today for 2 hours being so damn pissed of cuz the clutch doesnt engage properly.. I think the issue is because of the pressure plate which I used off an S197 ( spec stage 2 ). Anyway, I took everything off. Driveshaft, starter, transmission and clutch. gonna get a brand new clutch this week, I think I'm going with Centerforce or Ram clutchs.
The clutch I got from you dalamar doesnt have the same splines as the transmission I have which is stock 2004.
Will keep ypu guys updated.
T
Tungstenizer_GT
Guys, I really need help here.
Bought a new clutch along with friction plate from spec stg 2.. I installed everything again.. but the thing is when I try to hit the clutch pedal ( for testing ) the pedal wont come back again. now what could cause this ? I really need help.
I checked with my buddy who runs a shop on your clutch question, if the pedal isn't coming back up, it's probably because of your quadrant. you should replace the stock plastic quadrant with an adjustable (aluminum) one, then you can set the cable slack where it needs to be.
T
Tungstenizer_GT
I already have the aluminum quadrant, the problem seems to be from the under side..
T
Tungstenizer_GT
YESS SIIR... got the updates ready..
Been working on the car.. facing problems and solving them everyweekend.. been taking pictures too.. the car is 85% almost done.. all that is left is some fittings and some wiring and there you go...
The New clutch.. installed ofcourse
We now start the fuel system... here is how it looks right now..
The pipes and all hoses are installed and the install was not bad except for the rivet gun being a pain in the ass..
Dual fuel pipes..
They go to each fuel rail.. and from both back sides of fuel rails intot the sides of the regulator and from the underside goes the return pipe.
FINALLY
i found some studs....
Interior shot so far
Trunk installed back ON
Someone is mad because the hood is hitting its head.. LOL
Mr. intake manifold... have no fear SAUD will make the pain dissapear..
This is what happens when u dont wear saftey googles..
AT 2 AM
LOL
dafizuck
Definitely a sweet build and unique. Read it a few times... thought Id let you know it looks like youre doin good work. Are you going to pick up a new hood??
T
Tungstenizer_GT
Yess what you see is just the beggining to start the car.. once it starts, I am going to register it, next step will be heads, cams ,and a T-76 single turbo..
and as for looks.. am going with a Carbon fiber cowl hood and a carbon fiber trunk and a 98 cobra rear bumper and I am still trying to find something nice for the front of the car..
nice progress!
do you like the cobra front cover?
do you have any plans to upgrade the front brakes? you may want to put that on your list if your going turbo.
(that will be bad ass) :)
T
Tungstenizer_GT
Ahh yess the brakes for sure..
I'll be installing all over STRANGE billet brakes and I will also be deleting the Hydraulic Power Steering and get the whole new rack pinion from flaming river.. heard they are great..
The car will have 0 comfort for sure.. but god help me i will paint brush a ford logo crushing a Chevrolet hehe..
Good man, good man! :eek:ccasion14:
T
Tungstenizer_GT
Well,, I like the 2001 cobra front cover, But I heard even after the custom install I'd have problems.
T
Tungstenizer_GT
Hell YESS BROO..
Installed Front bumper, fuel tank, Fuel pump, Wired the fuel pump, Wired alot of crappy stuff under the dash, cleaned the messy look under the dash, CUSTOM COOLANT RESERVIOR.. lol aluminum made and looks sexy,,, Needs to be mirror polished.. ( No time ).. Some other crap also installed like the engine starter wires, ignition coils, fuel rails ..
THE GOOD NEWS IS..
we installed the battery and we got a response from the gauge cluster and all that.. we didnt start the motor yet we need
Belt
and to figure out the wiring of the steering unit.. I really need to talk to a good electrical dude.. who do u think might help me ?
Thanks.
US Soldier(stang 98)
Dixon IL
Re: Project '' The Hooker '' _-_-_ 7/17/2009
Man i wish could bro but the type of ellctrical your doing is way over my head, wish i could help out more.. thats bad ass tho that you got life in the computer system so far. good luck man you stang is going to be sick when its done. the car has come a long way from day one of this build
T
Tungstenizer_GT
Well so far so good, Were waiting on a tune that will dissable all the PATS and security system. I also found out that the ignition fuse was gone so I changed it now the car can turn keys ON. ( Jus tthe accessory lights ).. So i tried to put the xcal 3 to see if there is anyconnection.. yess there is but it wont be able to tune.. there is some other problem with connections.. I'll have to reall go throught every wire I can see and make sure it's grounded perfectly and connected perfectly.
I won't be able to crank the car due to not finding the original powersteering pump, I really don't know where it has gone, Might go to the scrap yard later to see if I can get my hands on one.
we also connected the headlights, dim lights and tail lights.. although there is a problem with the tail lights as we can't seem to connect the signal and brake lights.
shagg9
