Question on Oil Pans
Win
Kennesaw, Ga
So since i will have to tap my oil pan for the V1 i have been looking around. I found a couple fox oil pans and was wondering if there is any difference between ours and the fox body pans. I figure i might as well upgrade to a high volume oil pump since the FRPP unit is only 50 bucks.
Adam95GT
I forget weither the fox pan is the same. But i will tell you that you dont want to run a high volume pump with the stock pan. Mine hit the pan and cracked it. This is up for debate but several people argue you can suck the pan dry.
rz5.0
Great state of TEXAS
Same im running a fox pan right now. High volume pump usually dont clear stock pan. Unless your road racing I would not bother with a high vol pump
modo
Philadelphia, PA
also when running a high volume pump it is a really good idea to use a hardened oil pump shaft. stock can twist easily with the additional drag from the higher volume pump
Adam95GT
High volume pump pushes through the pan.
Stock pump clearance
LAFENATU
Just get a nice melling pump from AutoZone etc.
No need for a hi-volume.
Paul
Agree with Rob.
Also, take the pump out of the box, remove the bottom cover and inspect for nicks or other casting imperfections in the housing and the gerotor. Reassemble, making sure to use red loctite on the little bolts.
Paul.
