quick question about gas and need quick answer
5.0kid
do you need premium gas with just a cam in the engine? or will it run a little more rough with out premium but still run good? i found a car but i'm not sure cause he puts premium in it and said it runs a little more rough (with the cam) when it has regular in it. i want to figure it all out today so i can call him back.
95-stang
Our gas varies to yours, but most of the people i know with even slight mods run the super unleaded, rather than the standard unleaded. It wont do any harm except to your wallet.
cntchds
Change the timing back to the stock 10*BTDC and you will be fine. Just remember to change it to ~12*BTDC when you run higher octane gas.
This is what I've heard at least.
97 king cobra
its all in the timing, although im not sure how that would work for cars that have upgraded internal parts, i just have bolt ons
Paul
I run 89, and sometimes even 87, but that's because I rarely floor it. My car pings like a sumbitch even with 91 octane (limp wristed fairy juice) which is the best we can get here. I only run 6* initial timing even.
When I go to the track, I mix in a few gallons of 100 octane unleaded to get rid of the dreaded ping. Meh. Phoenix gas sucks ass.
Paul.
5.0kid
so if i switched it back to stock timing it would be fine? forgot to say it was at 14' timing.
Schiffy
Norfolk, Va
I only put in 87, with the occasional 93 when i feel like being nice (meaning when gas isn't $4/gal) I'm going to check my timing this week, my car is a turd, and i think that might have something to do with it...
had a buddy run his turbo'd fox on the dyno a few weeks ago, made a few runs on some wawa gas, drove down the street to shell and filled up,cam back and put her back on the dyno and picked up 25rwhp just off the gas from a different station :nonono:
5.0kid
thanks for all of the replies! i think i am going to go with my friend's aunt's BAB gt. it needs a little work on the exterior but it runs and drives great! it is all stock except flowmaster mufflers (welded on) and i should be picking it up next week cause of a radiator resevoir leak. i'm so excited!
Schiffy
Norfolk, Va
wrong thread homie...
5.0kid
sorry, i was just trying to state that i'm not going to get the car that only runs on premium right now.
trav_19
most people run premium when its not needed...mainly when gas octane rating need to go up...(burn slower) is when the compression ratio is changed ....does the cam actually change the c.r....? :dunno:
Mr. OAM
The cam timing does actually change the dynamic compression.
Static compression is what you calculate with your build spec's. My wife's 331 has 9.6:1 static compression.
Dynamic compression is what results from cylinder volume and valve timing events. When your valves open and close will have an effect on how much actual volume of air/fuel is captured in the cylinder and the resulting compression based on stroke and combustion chamber volume. To get nitty gritty, time actually factors in as well (RPM).
A cam with a shorter valve lift duration creates more dynamic compression. A cam with a longer valve lift duration creates a lower dynamic compression. That is why you run higher compression with long duration cams. This is a general statement because valve timing on the valves is what actually effects dynamic compression, but higher readings are typical with short duration cams and low readings with long duration cams.
This is how what cam you are running effects your octane requirement. On my wife's 331 with 9.6:1 compression and aluminum heads she runs 89 octane all the time. The timing is at 10 degrees BTD center. At 14* degrees it doesn't get any knocks or pings but it doesn't idle as nice as it does at 10*. It also idles faster at 14* than she likes. This is with 215* duration on the intake side but when the valves actually open and close in relation to each other (adjoining intake and exhaust events) comes into play. Anywaus this is what works on the street. Taking it to the strip I might bump it up to 14.
Steve
5.0kid
well, i'm trying to figure out what all im going to do with these heads i have. I think i may just wait a while and do a head/cam swap later this summer then an intake swap after that. does anyone know a good place to get a custom cam? I want to keep using 87 octane fuel and was wondering if a custom cam would be the way to go then. anyone have any suggestions? or should i just use the stock cam and do an intake and head swap?
trav_19
all 3 suck major on our cars i think the worst part is the intake ....they had to make one last minute to fit under the hoods and they dont flow so well ...very restrictive....if i was you i would do a head cam since they are harder to do and you can pull the intake after those are on with no problems but i would talk around and get prices on porting your intake it will greatly help
