quick question - ball joint press
dutch
I need to put some steeda X2 balljoints in the Cobra because the stock joints are shot to bits. (03 cobra arms are discontinued, thus getting too expensive). I called some shops, but I can't rent any press to put them in, so I have to buy one. Not really a problem, there's several on ebay.
Anyone with experience in this job tell me what one I should get?
I was looking at this one:
http://cgi.ebay.com/ebaymotors/NEW-3-IN-1-BALL-JOINT-U-JOINT-C-FRAME-PRESS-SERVICE-KIT_W0QQcmdZViewItemQQhashZitem5886c2dd44QQitemZ380218039620QQptZMotorsQ5fAutomotiveQ5fTools
thanks!
greenscobie86
The Big Apple
I just did the Ball Joint dust boots on my Cobra the other day.
While I didn't remove the b/j itself I would think that with the puller/air tools it wouldn't be extremely difficult....
The tedious part is taking everything off to get to the ball joint itself.
Overall I would say it is not too hard of a job, just time consuming. Make sure you have air tools.
GT Rob
Houston Texass
I changed mine about a mouth ago not hard but I did use that same c frame press and it did the job.Rented mine from auto zone.But if you need to have one thats a good price
427danderson
+1 but I did mine a year ago...
Win
Kennesaw, Ga
It's alot easier also if you have a vice where you can clamp the A Arm into. Ask me how i know GRR
mrdeep2001
were you getting any signs of a bad ball joint prior to it failing, or was it just all of a sudden?
dutch
dutch
balljoints were shot when I got it, front end was squeeking badly.. lubed m up, a little better now, but still need replacing.
Just ordered some MOOG replacement ones, 1/3 the price of the steeda's!
slo1
Its really easy I did mine about 6 months ago with arms on the car pressed out the joints and pressed them back in in 10 mins with hand tools no air. I thought it was going to be a pita but turned out to be simple.
97ponygt
If they're lowered I would have went with the steedas to improve suspension geometry.
